Old 04-25-2014, 09:16 PM   #21
dannyabear's Avatar
Originally Posted by D-maxx dave View Post
No porpoising, just jerking motion. No sounds, and if anything was loose, I'd think I would hear it. Smooth stops and starts. Shocks are probably the way to go. And slowing down on our Louisiana back roads. And front roads! Lol!
Simply cross the state line in any direction and it will get better; not much hope for our roads
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 04-25-2014, 09:21 PM   #22
puff's Avatar
Is the 5th wheel hitch located above, behind or forward of the center of the rear axle..? Above could be an issue if your light, behind the axle is never a good spot. You should be forward of the center line of the axle.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-25-2014, 10:11 PM   #23
D-maxx dave's Avatar
Looked at that. Receiver is above the yoke on rear end. Companion puts pin just behind the axle centerline. Thought that was the problem, but that's where it should be according to b&w instructions.
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 04-25-2014, 10:41 PM   #24
Red Wolf's Avatar
The first state that popped into my mind was "Louisiana", even before I looked over to see where your profile said you were located at.
-Red
Big Bad Wolf - '15 Dodge Ram 2500HD 6.7 CTD / Reese 15k Pro
Wolf Den 3 - '14 Rockwood Signature Ultra Light 8280WS
Nights camped 2017: 12
Red Wolf is offline   Reply With Quote
Old 04-26-2014, 03:29 PM   #25
Helmsey's Avatar
I'm betting you can resolve it once you go across the scales and see your actual pin weight. I can tell when mine is light as the ride is less than desirable. If I had to guess, you are light on the pin.
FWIW I have my B&W Companion (3500) mounted as far back as it will go and have no issues. I'm 99% sure GolfMedic has his as far back as it will go as well.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 05-02-2014, 02:54 PM   #26
Hope I did this right(Doug?). Weighed truck with me, full tank, an assorted junk(200lbs). 8100lbs. With gvwr of 10000. Gcwr 24500.
Steer axle 4700lbs.
Rear axle 3400lbs.
Hooked to camper: 21340.
I know I'm over as is, but how do I figure the pin wt using these figures?
David & Kelly
Old 05-02-2014, 03:18 PM   #27
Fulltime family RVer
Steer axle 4700lbs.
Rear axle 3400lbs.
Unfortunately, that's not enough information. We can tell how much your camper weighs (21,340 - 8,100) but that's it. We need to know what the truck itself weighs when the camper is hitched to it to be able to subtract the "unhitched truck weight" from the "hitched truck weight".
The reason that you want to get axles weights is so that you can find out where your rear axle falls in relation to it's GAWR (gross axle weight rating).
ependydad is online now   Reply With Quote
Old 05-02-2014, 03:28 PM   #28
-You need weight the TV front and rear axles empty
-weigh TV front and rear axles with RV hitched up
-weigh RV axles all while hooked up
Hitched
1) Front Axle-
2) Rear Axle-
3) Trailer both Axles-
4) GVW Truck= 1+2
5) GVW Truck and Trailer= 1+2+3
Unhitched Truck
6) Front Axle-
7) Rear Axle-
8) Truck Weight (6+7)
Pin Weight calculation as follows
9) 4 - 8= Pin Weight
Total Trailer Weight
3 + 9
Its a little confusing how I presented it.
SKGCRD is offline   Reply With Quote
Old 05-02-2014, 03:32 PM   #29
I'd argue, it's strangely a little confusing no matter how it is presented. ( )
I was thoroughly confused until one day it just all kind of clicked. Don't know what I read that it finally made sense, but it happened.
Old 05-02-2014, 03:35 PM   #30
Going back to the scales Sunday! Camper's setup on intracoastal waterway(crabbing, fishing, family and friends!!!) or I'd do it this afternoon. Post additional weights Sunday eve. And she's still chucking!
Thanks everyone!
David & Kelly
