Old 04-22-2014, 09:39 AM   #1
D-maxx dave's Avatar
Frustrated!
2012 CCSB chev d-maxx, 2015 piper 355 re with trail air rotaflex. B&W t/o with 3500 companion. Chucking! Jar your teeth chucking. What do I do? Brakes are set light, camper tv seem level. Roads are bad, understand this doesn't help, but not knowing it's back there. Never. And I read somewhere on the forum that airbags and the rota flex will work against each other?
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 04-22-2014, 10:00 AM   #2
Always Learning
Man, I'm sad to hear this. I thought the Trail Air Rotaflex was supposed to help with that quite a lot.
Old 04-22-2014, 10:04 AM   #3
Shocks would certainly help, at least mine do.
Old 04-22-2014, 10:26 AM   #4
AquaMan's Avatar
Shocks will help, to a certain point. Installed on mine, but still get chucking, I'm sure it helps more on shorter, lighter trailers. Not sure it will ever go away. What the shocks did accomplish, was to recover from the big dips much faster and took away a lot of bounce being transferred to the truck. Did very little for chucking.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-22-2014, 10:39 AM   #5
If I understand chucking, it is caused by worn/loose pin jaws, worn pin, hitch not solidly locked to rails.
When we first got ours, the 4 legs on our Reese 16K hitch had about 1/16" gap between the rail and the leg. I cut and welded 0.075" thick steel shims and now have to drive the pins in, but there is no chucking. When they put the slider in originally, it was much worse which is why we had it removed.
It takes less than 1/8" total "slop" in the hookup to make it a nightmare inside the cab. At least it did on mine.
Old 04-22-2014, 11:26 AM   #6
I've studied it. New camper, new hitch, all tight. Lube plate. I'm so worried about pin wt and cgvwr, that we're hauling lighter than with the TT. Is it possible that I don't have enough wt on the pin? That camper is trying to separate with an upward motion? Or, should I quit whining, because some chucking is to be expected with this much camper?
David & Kelly
Old 04-22-2014, 11:31 AM   #7
transamz9's Avatar
Did you torque the draw down bolt in the 3500's receiver?
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 04-22-2014, 11:34 AM   #8
Yes. Posted elsewhere about dealer installing and missing the drawdown plate. That'll never happen again!
David & Kelly
Old 04-22-2014, 11:35 AM   #9
AquaMan's Avatar
Chucking originates as a truck passes over a bump in the road, the truck is "slowed" and the trailer lurches forward, then the trailer hits the bump and is "slowed", thus pulling back on the truck. The lurching and pulling (back and forth) is chucking, a bouncing action (up and down) is referred to as porpoising. When you get into a rhythm, (concrete highway expansion joints) this can all be exaggerated. I don't think you will ever be able to get rid of it completely, but some things do help.
Old 04-22-2014, 11:45 AM   #10
No porpoising, just jerking motion. No sounds, and if anything was loose, I'd think I would hear it. Smooth stops and starts. Shocks are probably the way to go. And slowing down on our Louisiana back roads. And front roads! Lol!
David & Kelly
Old 04-22-2014, 01:24 PM   #11
jevanb's Avatar
factory shocks are notoriously crappy, get some bilsteins, or rancho`s
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-22-2014, 01:32 PM   #12
We're talking putting shocks on the trailer as a possible solution.
Old 04-22-2014, 01:37 PM   #13
golfmedik's Avatar
Some chucking problems are from too light of a pin weight. If you don't carry water with you, try filling up the tank as it may help(depending on where the actual tank is in the frame). Doesn't hurt anything and only takes a few minutes to try. My camping buddy just bought a new Wildcat and had the same problem. Added water and made it much better. He has since drained it, but rearranged some stuff in the nose to help.
Monty
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 04-22-2014, 01:37 PM   #14
KYB monomax. Great shocks for very good price.
2014 Crusader 330MKS Touring Edition
2006 Chevy 2500HD, Duramax/Allison
Firestone Ride-Rite air springs
SuperGlide hitch
Tbonnett65 is offline   Reply With Quote
Old 04-22-2014, 01:44 PM   #15
Originally Posted by golfmedik View Post
Some chucking problems are from too light of a pin weight...
X2
Old 04-22-2014, 02:54 PM   #16
Thanks everyone! Think 1st thing would be get to the scales, and axle out. Go from there, 5ver shocks sounds good in any case.
David & Kelly
Old 04-24-2014, 12:52 PM   #17
X3 on the KYB Mono Max
2013 Flaggstaff 8528RKWS 5th Wheel Diamond Pkg.
2005 GMC 2500HD Crew Cab LLY Duramax/Allison
Banks exhaust, AFE intake mouth piece, Volant CIA with ram air scoop, KYB Mono Max shocks, EFI Live by duramax tuner 5 tunes with turbo brake, B&W Patriot 16K Hitch
Paul J S is offline   Reply With Quote
Old 04-25-2014, 01:27 PM   #18
The mono max are for camper?
David & Kelly
Old 04-25-2014, 08:58 PM   #19
Shocks for the truck
Old 04-25-2014, 09:04 PM   #20
Yes. Sorry. Shocks for the truck, not trailer.
SuperGlide hitch
