Forest River Forums
Sunline User Photos
Old 08-22-2011, 07:22 PM   #1
Question Fuel Milage towing 11000 pounds
Hello, new to this forum. The DW and I are considering buying a 2004 Cardinal 29RKLE that has an UVW of 9760 pounds. Figure loaded (no water) I imagine the RV will be close to 11,000 pounds. I will be towing with a 2007 Ford F350 dually diesel that will basically be unloaded except for the DW, me and our dog (approx 350 lbs[all of us]). The most weight I've towed previously was approx 8000 lbs and I'd get 10-13 MPG on average. For those of you towing something similar what do you normally see for MPG when in flat country as well as in mountains? I know I shouldn't be concerned about milage but still am curious. Other RV's with similar layout (such as Crossroads Cruiser) only weigh 7500 lbs empty thus considering those because of the weight. Hope this makes sense and thanks in advance. Roy
Chief-e9 is offline   Reply With Quote
Old 08-22-2011, 07:27 PM   #2
too fast turbo sled
f1100turbo's Avatar
I dont believe that 3,000 more lbs. is going to make that much difference . altho it may decrease your mpg's some its not going to that much that it would be a deal breaker imho. i think the biggest thing with any tv is to be smooth and steady and keep the rpms as low as possible ie, 55 mph
I went up 3,000 lbs on my gasser tv and it stayed the same altho I went from a tt to a 5er .
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 08-22-2011, 08:02 PM   #3
The frontal area of the camper and the aerodynamics of the nose will make a lot more difference in fuel milage. And don't forget that a lighter camper of the same size will not be as robust as a heavier unit. The heavier campers usually have a heavier frame, better floors, and maybe thicker walls.
Many things to consider when buying a new camper!
Good luck.
Old 08-23-2011, 07:00 AM   #4
kz08h5's Avatar
I would expect your mileage would be about the same. As CROCUS stated, the frontal area has more to do with it than the weight.
We have a pontoon boat that trailered probably weighs 3500 to 4000 lbs. I get almost the exact same mileage towing it as I do my 6500- 7000 lb travel trailer. I get 10 to 13 mpg depending upon speed and terrain. As added proof that frontal area is the key mpg killer I have towed an open car hauler that weighed 6100lbs but the top of the car was at or below the height of the pickup bed. I was getting 14 to 16 mpg.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 08-23-2011, 07:52 AM   #5
jimh's Avatar
i have a 2002 Ford F350 crew duelly 4:11 rear end 7.3 diesel. i pull a 2002 Cardinal 33TS, 10200 lbs dry figure i'm close to 12000 when towing.
on level ground pulling at 70m/h, i get 8.3mpg very consistently. in the mountains it improves.
when i take the trailer on the Natchez trace, pulling at 50m/h, i get 10.1.
with no trailer on level interstate at 70, i get 17.5.
That large front area creates quiet a wind load.
believe the mpg improvement in the mountains is due to the slower speed.
worse i ever got was abt 7 and i may be being generous. was bucking high wind in S. Dakota. used almost all the 40 gal tank going from Mitchel to Wall.
jimh is offline   Reply With Quote
Old 08-23-2011, 08:47 AM   #6
Somewhere around 10 or less. How much is hanging in the breeze has a lot to do with MPG.
Foard County News & Sassy Schoolmarm
with Lady & Chloe (2012 days 22)
TT Killed 6/2011 - Getting used 2012 Unleashed 27 SBU
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 08-23-2011, 09:26 AM   #7
Now a "Top Member"
EdJunior's Avatar
You may be asking a bit much for 13mpg. Though with the 6.0L, you will probably get better. I get between 8.5 - 10mpg pulling my 5er, which is very similar to yours in weight, and I suspect design. As said above, it's that huge wall you're draggin in the wind more than the weight. But if you like the layout, that should be a bigger factor in your buying decision than the weight of the trailer.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
» Online Users: 594
111 members and 483 guests
1l243, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, autorot8, Bandit114, Barney1, bclemens, biken201, bikendan, bob34787, bobbygee, boubou, brandon0214, Browndog, Cafjackracing, case1175, chiro, chof16, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddavis662, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, DonG, Dukejr, dummin4fun, elind, forthefunofit, FreedomTracker, frfan, gbpacker, Gizzerd, Gman88, Gollum, Happy Vibe, HWII, isz, itat, JamesR, jasni, Jeep4Two, JJones, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, Kevin-and-Julie, kfroe, kjoh75, LFugate, lochsa, lowbubba, Mad4sax, McLuer, mesquiteguy, mhartzel, mia, Mr. Legato, mrmurph, MT28rk, mtnguy, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, ret2006, rkswyo, Rogue69, ronhanson, Rsgtivr6, rstewart06, SabreMarv, SabreSam, Sailfish Bret, sbond, ses, SimchaSabre, skippy31405, snowbrid, southernsky, spike, Steve7575, texashatter, TheFlagGang5, Tincup13, Titleguy, tking1866, tmmar, toleworks, torben, viper48, VTX Al, wayne anthony, we2lovecamping, whj77372, Wichitalineman, woodchomper
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
