Old 01-25-2019, 06:46 AM   #1
Good Ole Dad
G.O.D.'s Avatar
Fver with a 1/2 Ton
Who Tows a Fiver with a 1/2 ton Truck? I had a Salesman at an RV Dealer in Laughlin Nevada Show me a Grand Design Fiver that I supposedly could Safely Tow with My Truck. What do You Tow and What with? Thank you.
2016 F150 Super Crew 4x4
V6 3.5 Turbo, Auto 6 Speed, Axle=3.55
Rear Air Shocks. Ride Rite. 10 PSI.
Anderson No-Sway WDH
2014 Cherokee Grey Wolf 23BD.
G.O.D. is offline   Reply With Quote Reply
Old 01-25-2019, 07:03 AM   #2
SRN
He's right - you could safely tow it OFF his lot, then it's YOUR problem. Learned a long time ago RV sales people will tell you whatever it takes to make that sale. I was told once I could pull a 32' TT with the 6cyl SUV I owned at the time. Good for you for questioning first before signing on the dotted line.
SRN is offline   Reply With Quote Reply
Old 01-25-2019, 08:01 AM   #3
You may find this thread useful:
Do real 1/2 ton 5th wheels exist?
Skip12 is offline   Reply With Quote Reply
Old 01-25-2019, 10:06 AM   #4
It all depends on your truck brand, if itís a Ford 150 you can tow the biggest campers thatís made. I saw a F-150 in Lincoln Nebraska pulling a huge BlueRidge bunkhouse. The owner said the truck pulled the camper great. It didnít really bother me as I was going into the Cracker Barrel to eat and he was leaving. I have had great respect for Fords ever since
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote Reply
Old 01-25-2019, 10:19 AM   #5
Prime Member
It's all about payload. Is the truck rated to carry the weight of the trailer tongue / pin plus any passengers and cargo? If so, your good to go.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote Reply
Old 01-25-2019, 10:22 AM   #6
rp53's Avatar
spock, you just ain't right
2017 Micro Lite 21FBRS
2017 GMC Sierra double cab Z71
rp53 is offline   Reply With Quote Reply
Old 01-25-2019, 10:25 AM   #7
Grammar Pedant
67L48's Avatar
You either get a really small 5er (like the fiberglass SCAMP types), or you need a rare F150. The new 1/2 tons can be optioned in such a way to make it work. However, careful planning is required.
Speaking to F150s (because I know them better, but it's probably similar with any other brand), it would be best to get a low-optioned trim level (XLT at most, XL is better), 2WD, 3.5 L V6 ecoboost, HD payload package, tow package, and pretty much no other options. This will maximize your payload and should put you at or over 2,000 lbs payload, 13,000+ tow, and 17,000 GCWR. Then, you can start looking at small to mid-size 5ers. But, it's highly unlikely anyone owns this configuration without ordering one.
If you have a commonly equipped F150 Lariat 4WD Crew Cab (or equivalent), then it's pretty much impossible to put a conventional 5er back there and be within ratings.
Current RV: 2018 Rockwood Mini Lite 2504S
TV: 2019 F-350 Lariat 4WD CCSB 6.7 PSD, 3,591 lb payload
67L48 is online now   Reply With Quote Reply
Old 01-25-2019, 10:26 AM   #8
Who Dares, Wins
doc73's Avatar
My brand, Artic Wolf, is marketed as a half ton towable 5er. It is about 11,000k lbs, rear bunks and 35ft long with a pin of 1700lbs..
They do make some smaller 5ers that I'd bet would be fine with with RIGHT half ton.
So after doing the factory tour for our brand in Goshen this past year they talked about the half ton rating.. It is for an f150, extended cab with the max tow package. It is the only truck that would have the tow rating and payload in the half ton truck world to actually legally pull this trailer according to the FR folk.. But it makes it half ton towable, and all the stickers just say "half ton towable" and nothing about the needs of havig a f150 max tow. The places I've been with my trailer, which I to with a 2500, would have killed a half ton had I just read the sticker and used my 1500.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote Reply
Old 01-25-2019, 10:27 AM   #9
Denver To Yuma In 90 Days
There are several real 1/2-tonable 5'vers...
Unfortunately, they are much smaller than what most people buying new campers really want.
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote Reply
Old 01-25-2019, 10:29 AM   #10
Broken Toe
Cowracer's Avatar
Never, ever, ever trust what a salesman tells you. If you buy too big a camper for your truck and overload it to the point where you break down in the middle of nowhere, or God forbid, get in an accident... Guess what? He still gets to keep his commission check.
Verify everything yourself. Always.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote Reply
