05-28-2013, 08:35 AM
Steve Jackson
FYI-Ford Engine Issues
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
05-28-2013, 08:36 AM
Here comes the excuses. .......
05-28-2013, 09:30 AM
Toyota has a similar problem with the 5.7 in the tundra when the truck will go into limp mode because of moisture getting in the air intake pump. But it's not happening during acceleration only does it at start up. Seems to happen more in wetter climates. As long as ford mans up and fixes the problem.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
05-28-2013, 09:32 AM
Camper Less Camping
Uh Oh...sounds like 400K EcoBooger trucks need a little fine tuning ,)
2013 Sabre 32RCTS-6 (sold)
05-28-2013, 10:27 PM
Oklahoma Proud
I reported on this problem a few months ago. My uncle (who works as a ford tech) told me at Christmas that the intercoolers would build up condisation and apon hard exceleration would suck the condinsation up into the intake and cause misfires and then imobilization. At that time he said that there was not a fix for this issue, I may see him tomarrow at a funeral, and will see if they figured anything out.
- he also stated that these trucks shouldnt even try to be used like a superduty like a lot of people seem to try to use them for. They are A HALF TON!!!
05-29-2013, 12:12 PM
What do turbo-diesel trucks do to prevent this issue?
Doesn't seems like a towing issue to me. Not worth the bashing it will probably generate here.
05-29-2013, 01:10 PM
Camper Less Camping
Great question...ya think the Ford diesel engineers would have cross referenced with the Ecoboost engineers during design/testing to catch this problem!?
05-29-2013, 01:54 PM
Oklahoma Proud
I'm thinkin that they are 2 different beasts- apples and oranges and they both grow on trees, akin to both types of engines having turbos- otherwise worlds apart.
- whens the last time you actually saw water come out of a diesels tailpipe? On gas powered vehicles its all the time
05-29-2013, 02:29 PM
Actually the 6.4 l diesel have the same concern,You would have though that Ford would have used that info when designing where the intercooler outlet was put(at the bottom of the intercooler where the moisture settles when it is condensed).
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
05-29-2013, 02:51 PM
Not an engineer, but I bet the huge difference in compression ratios has a lot to do with it. Plus the fact that gas relies on a spark to ignite versus a diesel relying on the high compression. I think the report I read said there had been a whopping 96 reports. Would seem to be very rare if that is the case.
05-29-2013, 03:19 PM
Actually, spraying a mixture of water and methanol directly into the intake is a popular performance mod for diesels. Boosts hp and lowers egts..no joke. Most use windshield washer fluid.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
96 reports to the NHSTB or what ever it is. I'm sure there are many more reported to dealers. A quick google search reveals it is a known problem to many.
05-29-2013, 03:21 PM
Very true. Never done, but have heard of it.
05-29-2013, 03:41 PM
On the same lines I have meth injection on my four stroke turbo snowmobile.
05-29-2013, 03:44 PM
Maybe it was all by design but Ford forgot to hook up the Meth tank...lol
Jason and Billie
2018 F-250, 6.2L
05-29-2013, 03:49 PM
Lol !
05-29-2013, 04:31 PM
Camper Less Camping
Yea, 96 "reported" cases is no big deal....unless you're one of the 96 and it happened at the worst possible situation!
05-29-2013, 05:32 PM
I had the issue on my 2012. They replaced the intercooler with a newer design and flashed the computer with a new program. That was in February and I haven't had any issues since (fingers crossed). During that time I haven't driven it any different than before and towed also.
2012 F150 SCrew EcoBoost
2013 Salem 27RKSS
05-29-2013, 05:55 PM
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
05-29-2013, 06:12 PM
most intercooler temps are around the 350 degree after compression, I had a snow water meth system installed but sold it because I did not use it enough, but wish I would of kept it, it lowered my EGT about 200 degrees and the intercooler temps around 150 (shot before the cooler) it had 3 stages, I never did run meth in it just water. first shot at 6psi, second at 12, and all 3 nozzles on at 18psi
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
