Old 07-07-2014, 08:11 AM   #1
Galaxy RoadRider ST Tires
OK, so I have 4 Galaxy RoadRider ST 205/75/15's on the TT and they are about worn out so it is time for new TT tires.
Do I need RV specific tires (if there is such a thing) or will any good radial tires work?
Skippy38 is offline   Reply With Quote
Old 07-07-2014, 12:37 PM   #2
DaveSchwartz's Avatar
You need either 'ST' or 'LT' tires. ST are 'Special Trailer' and are built to have enough sidewall flex to accommodate the side forces that tandem-axle trailers see in turns. LTs are stiff enough to handle it too but are probably overkill on a 24' trailer. Do not use 'P' (passenger) radials. ST are also (supposedly) built to spend most of their time sitting in one spot.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-07-2014, 12:40 PM   #3
Goodyear Marathon LR D
Old 07-07-2014, 09:02 PM   #4
I would tend to agree (obvious bias here) especially since the trailer has a max weight on the tires near 7000lbs (GVWR=7590, hitch=590) which is about 95% of LRC maximums.
The 2011 Coachmen Catalina 24FBS seems to have come with 14" tires so the 15" must already be an upgrade (or factory option). The smallest 15" GY Marathon LRD is 225/75R15 which will be a bit bigger than the 205/75 you have so check that you have enough clearance for tires that are a bit over 1" larger diameter.
They do look good though!
Old 07-08-2014, 08:37 AM   #5
Thanks guys. There seems to be plenty of clearance so I think that I will check out the goodyears
tire, tires
