11-09-2017, 07:37 AM
#21
Agree with finding the sweet spot on the whole setup.
Have a class c but how I drive it as far as rpms and how I take hills etc makes a big (relative term) difference in overall mpg.
Staying where the engine and drive train are comfortable and happy I got 9.4 last trip instead of 8.
Takes me longer to get where we are going but it is called vacation.
As others have stated short of something larger that wouldn’t notice the TT weight as much it comes with the lifestyle. Relax, enjoy life and camping with the family.
2014 3051S - First RV for us
11-09-2017, 10:41 AM
#22
I wish I could say there is an easy answer to improving fuel economy. And there are some things you can do to help, but the reality is 10-11MPG is about the most you will ever see from any kind of a gasoline towing setup. Diesels are capable of much better mileage, but at a much higher initial cash outlay, usually. Here are some things you can do to help improve fuel economy, both towing and not towing:
1. Check your air filter. If it's extremely dirty or clogged, clean and/or replace it. A dirty air filter can affect mileage slightly. (Don't expect more than 5% increase in mileage at best, unless the filter is totally shot)
2. Check your tire pressure. Make sure none of your tires are underinflated. When towing, I like to run my rear tires at maximum pressure (listed on the sidewall) and the fronts a few PSI lower. Trailer tires I run at maximum PSI.
3. Slow down. With my 2016 Silverado 4.3 V6 towing a ~5000lb Rockwood Mini Lite, I get 11-12MPG at 55-60, but at 65 I only get 10-11 at best. If there is a headwind, I frequently say 8-9 doing 65. Just backing off from 65 to 60 will likely give you a 0.5-1MPG gain, if you're currently driving 65.
Sadly, RVing and good fuel economy have always been mutually exclusive. Maybe newer tech will change this some day, but for now, ~10MPG is the best you can expect.
Towed: 2017 Rockwood Mini Lite 2304
Tower: 2018 Silverado 1500 4x4 5.3L V8 3.42 rear end
2017 Camping Season: 44 Nights, 4,580 Miles
2018 Camping Season: 48 nights, 7,216 Miles
2019 Camping Season: 52 nights, 6,721 Miles
2020 Camping Season: 67 nights, 7,268 Miles
11-09-2017, 11:06 AM
#23
Originally Posted by patpat
Why
Or just buy a truck with a diesel.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
11-09-2017, 11:11 AM
#24
Yep, run out and spend 60 grand on a new diesel truck will net you some better mileage. ☺
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
11-09-2017, 11:22 AM
#25
SInce the title of the thread is GAS mileage I will say that the lil Tacoma gets 100% better GAS mileage than any diesel on the market!
Myself, I personally will never own a diesel, until I do..
11-09-2017, 11:27 AM
#26
Or just be happy and don't whine about poor mileage. I only get 11.5 pulling 14,500 ...
#27
Georgia Rally Coordinator
And how many years to recoup the cost . Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-09-2017, 11:35 AM
#28
Hybrids are made for good gas mileage. Trucks are made to handle stuff. Diesel or gas i rarely hear anyone shopping for a new truck to get good gas mileage. It’s usually a purchase for a purpose and saving gas usually isn’t the reason.
11-09-2017, 11:39 AM
#29
Casey & Carolyn
2X
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
11-09-2017, 11:42 AM
#30
Is the OP whining or asking if they can do better? We know a gasser will likely get lousy mileage with appreciable improvement unlikely no matter what is attempted, but a newbie may have to learn that through asking and then through experience.
11-09-2017, 12:32 PM
#31
I get 8.5-9.5 MPG with a F150 Ecoboost 3.5L on premium gas pulling about 7500lbs. It's a V6, so you are right in the range for the size motor and shape/weight you are pulling. Sadly, this is the part of the RV experience that dealers and companies don't talk about. Also the ford, chevy and ram dealers inflate their numbers on truck abilities/MPG. A diesel is better, but you really need to calculate your ROI to determine if it's worth the $$$$.
11-09-2017, 01:27 PM
#32
Originally Posted by DNA Dan
....Also the ford, chevy and ram dealers inflate their numbers on truck abilities/MPG....
I don't think the dealers inflate anything. Their numbers are based off of unreal world conditions. I think the customers look at all the numbers and forget to add in the real life variables.
Will the 3.5 ecoboost tow XXXX pounds?...Yes.
Will the trucks payload be overloaded?......Very likely.
Will the 3.5 ecoboost get 20 MPG on the highway?.....Yes.
Under all conditions?....................................... .......NO!
While towing?........................................... ............Absolutely not!
As consumers, we look at every individual number advertised and think it will do that under all conditions. We need to realize that the numbers come from a small test pool under perfect conditions.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
11-09-2017, 02:00 PM
#33
Recently new!
.....and to add....have you seen how they actually test the vehicles for towing? it is with a loaded towable that is at best....and often lower than the tailgate of the truck tested. There is little to no wind resistance measured. Now, add an empty full size behind, watch how far the mileage will tank....even with no load. Wind resistance goes up exponentially with just a few miles per hour speed increase!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
11-09-2017, 02:39 PM
#34
Originally Posted by znate80
Buy a diesel, 15 mpg towing my Rockwood 2504s w/my ram 1500 eco diesel 4x4
Forgot to mention the 29 mpg at 70 mph I get also. There is nothing you can do to get better fuel economy out of your set up with out drastic changes (i.e. buying a new truck).
2002 Dodge Dakota
2021 Geo Pro 19FBS
11-09-2017, 02:59 PM
#35
Scoundrel
I have a 2017 Salem cruise lite. I tow it with a 2012 Toyota Tacoma V6 with a tow package. I get 8-9 mpg. Is there anything I can do to get better.
Thats a lot of trailer for a Tacoma. I get 12.9 to 13.7 with my Frontier but I'm pulling a much smaller (19 feet) & lighter TT. The 261 hp is adequate but suffers on steep grades. The suspension has been upgraded/lifted.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
11-09-2017, 03:23 PM
#36
A pop-up or Hi-lo trailer will do much better, an Airstream or Scamp will do marginally better. As it is keep it under 60mph, anticipate stops, accelerate or climb hills with about 3/4 throttle to keep it out of fuel enrichment mode, and remember all the money your V6 saves the majority of time you use it when you aren't towing. I may get 13 mpg with my fancy diesel towing but its not good for much else so it sits besides the house.
11-09-2017, 04:23 PM
#37
X2. Looking at the stats on the truck, and with his setup as is, it shows it's capable of pulling up to 6400 lbs. The Salem Cruise Lite 15bn that he has, it looks to be at roughly 3k lbs. "unloaded". It's a close match up, the headwinds may not be much fun, but it's doable.
I used to pull a 3k popup with a 6cyl Trailblazer and 6cyl Jeep GC. Was doable but I wouldn't win any races.
Sadly, the fuel economy isn't going to improve much, but they will still be able to go out and enjoy camping. Maybe a bigger TV will be on the OP's future Xmas list.
ENJOY!
Rick & Brian
2023 Flagstaff 206STSE
2019 Flagstaff HW29SC ( sold )
2017 Salem Cruise Lite 232RBXL ( sold )
2014 Ford 150 XLT 5.0 2wd
11-10-2017, 05:56 AM
#38
I'm towing a 5000lbs 233s with my 4cyl canyon diesel and getting 16-17 mpg!!! The wdh may help a bit by possibly leveling out the profile of the truck and trailer!
It's definitely a good idea to have a WDH!
11-10-2017, 07:03 AM
#39
And you drive a max of 50mph? That's some good mileage, seems to me.
11-10-2017, 07:43 AM
#40
I️ have a 2016 RAM 2500 diesel unloaded on hwy at 70 mph I’ll get 19-20 mpg. Pulling the 5th wheel drops to 13
