Old 10-28-2013, 10:22 AM   #11
Denver, CO
garbonz's Avatar
Slow down to 60. Thats the only way to appreciably increase MPG, regardless of what else you do.
2017 Fuse 23T
Old 10-28-2013, 10:38 AM   #12
wilem's Avatar
i concur with most all of what has already been said. but if you are having a lot of down shifting and the engine is lugging you could possibly see an increase. not much but it sure would reduce transmission heat and friction withing the torque converter (some refer to this friction as fluid shearing). the gear stated is not enough IMHO i would say you need a 3:73 or 4:10 especially if you have 2 OD ranges. it will however decrease you non towing mileage without a doubt. But i would be more concerned with transmission life than fuel mileage either way. I have installed dozens of gears and out side of towing you will not likely ever get better mileage with a higher ratio. YMMV
NOTE: you should see the things that happen when the fluid temp of a transmission goes over 200 deg/ valves stick, fluid temp runs away, fluid is vented at an alarming rate, sometimes onto the catalytic converter and then you have tons o smoke and maybe even a fire.
William
Master ASE
Private pilot SEL
A&P
jack of all trades master of one...LOL
http://imageshack.us/a/img32/3111/ypy.JPG
wilem is offline   Reply With Quote
Old 10-28-2013, 10:42 AM   #13
wilem's Avatar
this is the best way to increase mileage,
Air pressure increases exponentially with velocity so its painfully obvious that the faster you go the more it costs. I would install a roof wind deflector if they weren't so permanent... that would help a lot.
William
Master ASE
Private pilot SEL
A&P
Old 10-28-2013, 10:43 AM   #14
http://www.ringpinion.com/calculators/Calc_RPM.aspx
This might help.
rccktmn2 is offline   Reply With Quote
Old 10-28-2013, 04:22 PM   #15
bikendan's Avatar
as others have said, slowing down to 60mph would give you better gas mileage than any of the things you're thinking of doing.
and expecting a cap to improve gas mileage, has been proven many times NOT to work, just like leaving the tailgate down.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-28-2013, 07:11 PM   #16
great advice everyone. so maybe I'll go for the 3.92 ratio as that is as low as I can go. There is only like $10.00 difference in price between the 3.55 and the 3.92.
kwbybee is offline   Reply With Quote
Old 10-28-2013, 07:43 PM   #17
Do you have it in tow/haul mode? I have essentially the same mix and do not find much gear changing.
A long time ago I had a GMC 454 1 ton with a slide in, a cattle rack or most often just an empty bed. Mostly I found the mileage was limited (or maximized) by the flow through a 3/8" fuel line. Generally 8 mpg uphill with the slide-in camper and sailboat or 8 mpg downhill with an empty bed and the tailgate down.
Timtation is offline   Reply With Quote
Old 10-29-2013, 11:21 AM   #18
i have a 2013 Ram 1500 5.7 with the 3.92. the most i get with the ac on towing around Texas is 10mpg TT is right at 4k loaded for the weekend. and i tow at 65 on the freeway. You almost get run over in the 75mph area's
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 10-30-2013, 10:24 PM   #19
Hey Prothos, what is your fuel mileage when not towing?
Old 10-31-2013, 08:36 AM   #20
I run at 55 mph, and get even better mileage! I know that probably ticks some people off, but that's what 4 lanes are for. On 2 lanes when traffic builds up behind me I pull over and let the traffic pass! Last summer on our way to Branson and back I was getting 14 + mpg with the wind in my back. 10 to 12 with no wind conditions. Safe travels all!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
