Old 10-31-2013, 09:27 AM   #21
Originally Posted by kwbybee View Post
great advice everyone. so maybe I'll go for the 3.92 ratio as that is as low as I can go. There is only like $10.00 difference in price between the 3.55 and the 3.92.
If your truck is 4x4 there will be a BIG diff.in Price! Youroo!!
Old 10-31-2013, 09:36 AM   #22
wilem's Avatar
Originally Posted by prairiecamper View Post
I run at 55 mph, and get even better mileage! I know that probably ticks some people off, but that's what 4 lanes are for. On 2 lanes when traffic builds up behind me I pull over and let the traffic pass! Last summer on our way to Branson and back I was getting 14 + mpg with the wind in my back. 10 to 12 with no wind conditions. Safe travels all!
Nothing wrong with that, I try to tow in a place that suits the current gear selection. There is a window for each gear, I don't like to sit on the fence of at say 55. When 5 mph more or less is easier on the system. I say system because I am a transmission guy I watch my trans temp closely. You need for the converter to be locked for the trans to cool down. ( when a trans goes into hot mode it applies the TCC. To help it cool down)Whatever makes it stable is what I do. The new diesel I have has much much wider windows of operation. And that is simply because of more torque. The Allison transmission is a beast compared to what I was using. The rear axle and brakes are much more stout as well. Happy truck = happy trip.
William
Master ASE
Private pilot SEL
A&P
jack of all trades master of one...LOL
https://imageshack.us/a/img32/3111/ypy.JPG
wilem is offline   Reply With Quote
Old 10-31-2013, 09:48 AM   #23
wilem's Avatar
Why? Price within a ratio or two is usually pretty close. Unless you jump so far you have to change carriers. Say from.2.73-4.10. Then a thicker Gera or new carrier is required.
William
Master ASE
Private pilot SEL
A&P
Old 10-31-2013, 10:30 AM   #24
Perma-Newb
4X4 is more expensive because you have a set of gears in the front axle also (twice as much??). My F250 has 3.73, this gearing came standard with the tow prep package. I’m of the opinion that towing a TT is towing a TT regardless of what snake-oil/voodoo tricks you may try. The only thing that may work is lowering your speed (55mph), and lets face it, you’re camping, what’s the rush anyway
2015 F350 Dually, 6.7 PSD
2014 V-Lite 30WIKSS, Diamond Package W/All the goodies
https://www.forestriverforums.com/attachments/signaturepics/sigpic50858_1.gif
EarlyRetirement is offline   Reply With Quote
Old 10-31-2013, 11:16 AM   #25
Your shifter on that 09 Ram has a tow haul button that can eliminate both overdrives. Pressing it one time will illuminate the Tow Haul light on the dash this eliminates 5th gear and results in about a 250 RPM increase. If you press the button again the OD off light will illuminate and this locks out both 4th and 5th gears and keeps you in 3rd wich is a 1:1 ratio this would bump your RPM up quite a bit. I swapped the 3.73 out of my 2500 for a set of 4.56's and tow in 3rd gear. 60mph is about 2800 RPM's I stay between 55 and 60 my camper is large and asks alot of my truck but it does the job. Try seeing how the OD off does for you that would keep you in 3rd gear and eliminate any gear hunting for sure. This OD off feature was not available until 2006 on the gas Rams you could only eliminate 5th gear for the measley 250 rpms it was worth
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 10-31-2013, 11:33 AM   #26
The statement has been made that “the lower your gear ratio, the greater the RPM's from your engine to maintain an equal driving speed.”* I am confused (not an infrequent occurrence).
Assume, for purposes of illustration, that the gear ratio is 2 to 1. As I understand it, that means the drive shaft rotates two turns for each one turn of the wheels. If the gear ratio is lowered to 1 to 1, the drive shaft must now only rotate one turn for each one turn of the wheels. Therefore, it seems to me that engine rpm's necessary to maintain an equal driving speed is lower when the gear ratio is lowered.
What is wrong with my understanding of this relationship?
Al Fresco is offline   Reply With Quote
Old 10-31-2013, 11:42 AM   #27
Perma-Newb
Originally Posted by Al Fresco View Post
The statement has been made that “the lower your gear ratio, the greater the RPM's from your engine to maintain an equal driving speed.”* I am confused (not an infrequent occurrence). Assume, for purposes of illustration, that the gear ratio is 2 to 1. As I understand it, that means the drive shaft rotates two turns for each one turn of the wheels. If the gear ratio is lowered to 1 to 1, the drive shaft must now only rotate one turn for each one turn of the wheels. Therefore, it seems to me that engine rpm's necessary to maintain an equal driving speed is lower when the gear ratio is lowered. What is wrong with my understanding of this relationship?
Think of gears on a bicycle. The higher the gear, the easier it is for you to pedal, but you burn more calories due to you legs spinning faster. Opposite is true for the lower gears, sure you can get going faster without spinning your legs so fast but it's harder to maintain speed.
Old 10-31-2013, 12:30 PM   #28
EarlyRetirement:
I agree with everything you say. Indeed, a higher gear ratio does equate to more torque. Nonetheless, this does not explain (at least to me) why higher engine rpm's would be required to maintain the same driving speed if the gear ratio is lowered.
Old 10-31-2013, 01:13 PM   #29
Al when talking about rear end gears it is the relationship between the ring gear and pinion. Example a 3.73 gear mean the for every turn of the ring gear the pinion will turn 3.73 times. The pinion is driven by the driveshaft /transmission/engine. It all starts at the engine if it takes 3K rpms at the motor to turn the pinion wich is at the other end of the component ladder with a 3.73 to 55 mph then to keep the pinion at the same speed with a 4.56 it is impossible to do unless the engine all the way at the other end increases RPM. Tire diameter can also play a role in this
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 10-31-2013, 01:16 PM   #30
Or easier comparison do 15 mph with a 10 speed bike in 1st gear and then 10mph in 10th gear there will surley be a difference in the pedaling RPM.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 10-31-2013, 02:09 PM   #31
wilem's Avatar
EarlyRetirement:
The gear ratio is increased for more torque not decreased. As in 3.42:1 increased to 3.93:1will result in higher engine speeds. The are saying by decreasing the overdrive ratio will decrease engine speed . It can be over driven or under driven. It results in a positive or negative ratio
William
Master ASE
Private pilot SEL
A&P
Old 10-31-2013, 02:09 PM   #32
Iwannacamp's Avatar
Originally Posted by Badlands View Post
As the other respondents said, there are many variables, but changing to a lower gear ratio won't be aiding your mileage. Think of it this way; the lower your gear ratio, the greater the RPM's from your engine to maintain an equal driving speed. The higher the RPM's, the more the engine is working, and down goes the MPG. I go back to my muscle car days for an example, too. My Dodge Charger Daytona 500 had a 440" engine, and I commonly ran 3.91 gears, though the car came with 4.10's in it's Trak Pak format. For Saturday night bragging rights, I'd change the gear set over to 4.56's -- huge torque and extreme acceleration capabilities. But (and I don't remember the exact details -- it was a few years back), at 55 mph, driving normal and not abusing the accelerator, I lost 2-3 MPG with the 4.56's in the Dana axle, as opposed to the 3.91's. And, as you note, the effect of a headwind can be mighty humbling!
Memories. I had a 68 road runner... 440 souped up some..850 double pumper...bla bla it got 2 MPG on the highway before I installed 4:30 gears. Lol
2017 Puma 297RLSS
Old 10-31-2013, 02:10 PM   #33
Iwannacamp's Avatar
Originally Posted by garbonz View Post
Slow down to 60. Thats the only way to appreciably increase MPG, regardless of what else you do.
X2
2017 Puma 297RLSS
Old 10-31-2013, 03:43 PM   #34
wilem's Avatar
Well that goes without saying. I think his statement meant the price from one ratio to the next and that the labor was the same for either gear set. If he is going change ratios a ratio within a jump of one or two the over cost of the job should be the same or should be negligible he is coming from 3:20 something to 3.42 or 3.92 the cost won't matter enough due to which one he chooses.
William
Master ASE
Private pilot SEL
A&P
Old 10-31-2013, 03:59 PM   #35
JFM-jr:
Thanks for your attempt to allay my confusion on this subject.
Per your description, the drive train sequence is basically as follows: engine>transmission>pinion>ring- gear>>wheels. To a first approximation, the gear ratio is the number of teeth on the driven gear (ring-gear) to the number of teeth on the driving gear (pinion). Per your example, with a 3.73 gear ratio, the pinion must turn 3.73 times to cause the ring gear to turn one time. If, as in your example, the gear ratio is increased to 4.75, I understand that to mean that, for a constant engine>transmission>pinion rpm, the ring-gear>>wheels will make fewer revolutions than is the case with a 3.73 ratio. In other words, all other factors being equal, the speed will decrease at constant rpm going from a 3.73 to a 4.75 gear ratio. Say 2,500 rpm are required to maintain 60 mph. Again, all other factors being equal, with the lower gear ratio, would it not be necessary to slow (not increase) the engine rpm to maintain the same speed compared to the rpm required with the higher ratio?
Consider a bicycle traveling at constant speed on a flat road. All other factors being equal, if the gear ratio as defined above is lowered (i.e., the number of teeth on the driven gear effectively decrease relative to those on the driving gear) the rider must decrease the pedaling speed in order to maintain that constant speed. Otherwise the ground speed will increase.
To reiterate, I am responding to the claim that increased engine rpm are required to maintain constant speed with a lower gear ratio.
Old 10-31-2013, 04:18 PM   #36
Iwannacamp's Avatar
Ok...I from Arkansas. I talk slow, understand nothing and skip stuff when I read....so if I got anything correct then there are a few factors for fuel consumption basics. Friction:tires and weight maybe. Wind resistance: faster is more. Torque:horse power to weight/gear ratio. Somehow this math has to work for your hp/weight/fuel use.
Is this even close?
2017 Puma 297RLSS
Old 10-31-2013, 04:25 PM   #37
wilem's Avatar
i agree but most trucks run around empty and the EPA has pushed manufacturers to squeeze out every single bit they can..not to mention bragging rights among manufacturers for the best mileage on a pickup. the complexity, repair cost increase are definitely not worth it for a truck used like a truck.
William
Master ASE
Private pilot SEL
A&P
Old 10-31-2013, 04:27 PM   #38
Stg1's Avatar
Gee, you guys are smart. Me , I just get in the truck and drive, The only difference between towing and not towing, the Nissan has a right/left position on the shifter in drive. The left side lowers my rpms and I shift to the left when I get up to highway speed(usually 60). I guess I'm using the gear that provides torque to get going , then the other to maintain highway speed. I usually drive between 55 and 60 to get the best mileage. Gear ratio is 3.73.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 10-31-2013, 04:28 PM   #39
wilem's Avatar
more than twice as much, that front diff is a whole lot more involved than the rear. on say a K-5 or more current IFS the front labor is quite a bit more than the rear.
William
Master ASE
Private pilot SEL
A&P
Old 10-31-2013, 05:14 PM   #40
If, as in your example, the gear ratio is increased to 4.75, I understand that to mean that, for a constant engine>transmission>pinion rpm, the ring-gear>>wheels will make fewer revolutions .
Above is where your logic is flawed it is not the wheels making fewer revolutions but instead the pinion making more revolutions. The wheels/axles at 60mph is a constant this will never change regardless of gear ratio. What does change is the pinion revolutions needed to turn the wheels to that same 60mph. A 4.56 will need alot more revolutions to maintain 60mph than a 3.73 will the only way to increase pinion revolutions is with your gas pedal
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
