Old 05-17-2013, 06:08 AM   #11
F-350 Dually Gear Ratio
Originally Posted by PHS79 View Post
Here is the easier way to find the gear ratio, just go to the drivers door, look for the white tag, it will either be on the door or on the pillar near the door latch, and get the code where is says "axle". Then look here: Ford F-250/350 Series Gear Ratios
I found F2 on the door post sticker next to Axle. I went to the link provided and it said 4.1L. The owner's manual says it should be either a 3.73 or 4.33???? The "L" means limited slip differential.
mosesmcrae is offline   Reply With Quote
Old 05-17-2013, 06:18 AM   #12
Rolling buckeye's Avatar
Confused: 03 should be ether 6.0 or 7.3, and is most likely 3.73, as oaklevel said would be rare to be anything else.
Rolling buckeye is offline   Reply With Quote
Old 05-17-2013, 01:24 PM   #13
Twisty's Avatar
It may not be the correct manual for the truck -
6.0 - 6.8 - 7.3 ??
Did they even offer a 4.33 rear dif?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-17-2013, 02:44 PM   #14
Turns out it is a 6.0L Turbo Diesel with a 4.1 rear end. I found the tag on the differential. Apparently, I do have the wrong owner's manual. I've emailed Motorcraft with a request for the proper manual.
We'll see if they respond.
Old 05-17-2013, 07:39 PM   #15
That should be a good tow vehicle !
