Old 08-12-2017, 07:56 AM   #61
towing a parachute.
The 4.3 should keep you around 2000 to 2100 rpm at 63 or 64 mph.
markb422 is offline   Reply With Quote
Old 08-12-2017, 08:07 AM   #62
Cumminz's Avatar
I really don't like driving at 70. 63-65 would be great.
CumminZ
2017 Forest River Cedar Creek 38EL Champagne
TarHeel State
www.CumminZ.com
Cumminz is offline   Reply With Quote
Old 08-12-2017, 08:14 AM   #63
FirstTracks's Avatar
Originally Posted by W5CI View Post
Normally only 3/4 and 1 ton diesels have 4.10's. and not many of those.
My 1/2-ton Toyota Tundra has 4.30 stock.
Cottonwood Heights, Utah
2016 Evo by Forest River T2050 (23')
2014 Toyota Tundra 5.7L V8
Days camped in 2017: 32 (so far!)
FirstTracks is offline   Reply With Quote
Old 08-12-2017, 08:45 AM   #64
IF you know you will usually be traveling below the speeds on your highway , stop at a truck stop and purchase a roll of Conspicuity tape.
This will help folks spot your tail.
Amazon.com: Conspicuity Tape Hug Flight 2"x150' Dot Class 2 ...
https://www.amazon.com/Conspicuity-H.../dp/B00Y2CBBSM
FFred is offline   Reply With Quote
Old 08-12-2017, 10:32 AM   #65
dmdomokos's Avatar
Originally Posted by Moparman1230 View Post
I drove a tractor trailer for FedEx Express. I can tell you our trucks are governed to 63.
FedEx trucks on I15 in Utah don't go 63mph. They pull 2 trailers and drive 75 plus. If that's against their policy then these drivers are not complying.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 08-12-2017, 10:37 AM   #66
dmdomokos's Avatar
Originally Posted by Jonol View Post
m35a2, you look convince that your TT can stop faster then a big rig and that is fine with me, but be carefull ??
They have a lot more tires and bigger tires on the ground then my TT and my truck!
I think that feeling comes from what your TV is and what you're trailer weight is. I tow with a 3/4 ton and trailer is 7500lbs. Everybody's rig would be different. I haven't come close to sliding into a Simi when stopping in a hurry in stop and go traffic.
Old 08-12-2017, 04:49 PM   #67
Good Year Load Range E
Goodyear Endurance
Trailer Use Only
Sidewall Style: Blackwall
Load Range: E
Max Load 2,830 lbs
Speed Rating 87 mph
Max Inflation 80 psi
Made in USA
Coachman Freedom Express 320BHDS
Super 8 is offline   Reply With Quote
Old 08-12-2017, 05:53 PM   #68
tuckerdog1's Avatar
I would not concern myself with slowing drivers behind me. Stay to the right when possible. If not possible, be courteous when you're able to allow them to pass. I don't know when this was put together, but it appears speeds over 60/65 ( some states even lower ) are illegal in most states when towing a trailer.
http://onlinetowingguide.com/pdfs/StateTowingLaws.pdf
Tuckerdog
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB ( Mine )
2015 Genesis 5.0 ( Hers )
2016 Windjammer 3029W Platinum ( Ours )
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is offline   Reply With Quote
Old 08-12-2017, 08:37 PM   #69
m35a2's Avatar
I don't think I said that.
Whether I can stop faster than a tractor is irrelevant. What's relevant is that I know how long it takes me to stop, and that I make sure to have that distance available.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 08-12-2017, 08:52 PM   #70
Following Semie in center lane
Well good lock m35a2 if the trafic stop suddenly!
Be carefull out there!
Jonol is offline   Reply With Quote
mpg
