Old 04-23-2016, 05:52 AM   #21
Originally Posted by Sactd View Post
Brian
Thank you for your reply and insight. I will make sure I use a very competent welder. I'm computer illiterate and couldn't figure out how to send this through pm. Robert
Your welcome , To send a PM , click on the users name and you will then click on send private message.
Big Red and 30WR is offline   Reply With Quote
Old 05-14-2016, 03:41 PM   #22
Gen-Y Hitches now makes a torsion hitch with WD bracket already on it. They just got the first batch fabricated. Mine should ship next week. Here is a CAD image of the hitch.
5thwheel-in is offline   Reply With Quote
Old 05-14-2016, 03:42 PM   #23
Old 05-14-2016, 03:43 PM   #24
Mr. Truck Review of Torsion Flex Hitch:
Old 05-15-2016, 04:17 PM   #25
I asked them months ago about doing that. Got no response. I`ll email them and ask if I can buy the WD part and take the pintle plate head off. Save a lot on weight.
Old 05-15-2016, 04:37 PM   #26
5thwheel-in , Hope you enjoy yours , I like the one I put together, only down fall with mine is the weight. Its 131.2 pounds.
Old 05-15-2016, 04:57 PM   #27
My understanding is this one clocks in at about 80 pounds...and I thought that was heavy....
Old 05-15-2016, 06:54 PM   #28
That's just the geny hitch without the weight distribution head so with the head you will probably be in the 125 to 135 range . Just guessing on that.
Shipping weight on my pintle plate hitch was 60, my adapter I made was 32. Rest was bolts , handle and the equalizer head.
Old 05-15-2016, 07:04 PM   #29
Golly day.... I was assuming it was in the same weight range as an air safe hitch... I guess these dudes are really well made!
Old 05-16-2016, 05:31 AM   #30
Very well built and a lot less money than a air hitch. Easy maintenance as well. Just 2 grease zerks. My handle I built serves two purposes . handle to carry of course and also run my trailer cord threw it. Keeps it up on top and out of the hitches way.
Old 05-16-2016, 05:08 PM   #31
Just got an email from Gen-y.... My hitch weighs in at a approximate 70 pounds. Seems very manageable.
Mine is the 2 inch receiver version...that might explain some of the difference in weight...
Old 05-16-2016, 07:46 PM   #32
Mine is the 2 inch one as well. I use my receiver reducer. So your should be around 110 pounds depending on what WD head your using. If mine had a 60lbs ship weight , then I added 32 lbs adapter . Yours is 70lbs shipped, So I subtracted 20 lbs off my total weight to get 110 to 111 pounds.
Old 05-16-2016, 07:52 PM   #33
Oh got it, your weight included the WD head. I will be using a Blue Ox Sway Pro and attaching its 57 pound head to the 70 pound torsion flex hitch so I will end up close to 130 pounds...
Old 05-17-2016, 04:10 PM   #34
Please post pictures of your set up when you get it together . Thanks
Old 05-17-2016, 04:29 PM   #35
I will...one item I noted. The GEN-Y Torsion Flex Shank is 70 pounds. The Blue OX shank that it replaces is 25 pounds. So the Torsion Flex should add about 45 pounds to the overall hitch assembly weight.
Old 05-17-2016, 04:56 PM   #36
That's not bad @ all then .
hitch
