Old 01-20-2016, 06:01 PM   #1
Geny hitch
Anyone know if the geny torsion flex hitch can be used with a wdh? I emailed the company and as of now no reply back. Thought maybe it would work nice mated up with my equalizer .
Big Red and 30WR is offline   Reply With Quote
Old 01-21-2016, 08:19 AM   #2
MtnGuy's Avatar
What would you do..........insert the WDH into the Geny Hitch ?? I am not familiar with the Geny Hitch, but I don't think I would attempt such a move,
Old 01-21-2016, 05:26 PM   #3
Yes I would make a shorter hitch block that my equalizer head bolts too. That way it wouldn`t be so long and keep more weight closer to the TV. I got an email from the company . They said I could use a wdh with that hitch . I will have to call and ask more questions before ordering .
Old 01-21-2016, 07:22 PM   #4
MtnGuy's Avatar
If the Geny Company says it is good to go, then that is great. I am always learning.
Post a picture of your setup when you get er done.
Old 01-22-2016, 12:54 PM   #5
thebrakeman's Avatar
The gen-Y hitch bits are a means for a single vehicle to have the capability of pulling multiple types of trailer. Do you have multiple trailers?
If not, what problem are you trying to solve with the gen-Y hitch, air-ride hitch, etc? Using your Equalizer in this hitch may not be a problem. But what problem do you have in the first place?
thebrakeman is offline   Reply With Quote
Old 01-22-2016, 07:11 PM   #6
I have two trailers , but I`m interested in the torsion flex hitch too help with the herky jerky I get like when you go on and off bridges @ highway speeds. Or other road conditions like joints or potholes. My tongue weight is 1150 with rzr in garage without loading things in the front under the bed. Maybe with my 1200# bars and a one ton dually my set up is too stiff. I run 6 washers in the head , but would like alittle more weight up on the steer axle.I got molding I need to refasten mainly due to road shock and poor craftsmanship .
Old 03-08-2016, 07:14 PM   #7
I got the geny hitch model 1201, Got a few parts cut out for my adapter to bolt my Equalizer hitch head to . From truck hitch receiver end to center of ball will be 15.75 inches . Just 4.75 inches longer than the EQ head on current shank I have been using. So Its starting to come together.
Old 03-08-2016, 07:23 PM   #8
W5CI's Avatar
What is a Genny hitch, never heard that phrase before, just asking
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 03-08-2016, 07:45 PM   #9
Geny hitch is manufactured by easy hitch & haul out of Bremen Indiana. They make many different drop hitches and rubber flex hitch with uses the same technology as a torsion axle. Very well built for the money.
Old 03-13-2016, 08:01 AM   #10
I decided to do a mock up of what it would look like . I currently don`t have the adapter plate welded up yet. When done I`ll be sure to give to a update on how it worked on the road. Click image for larger version
hitch
