Old 11-17-2013, 06:40 PM   #61
Rugged Brown's Avatar
Originally Posted by grayfox View Post
Who wrote the song ? Don't look it up.
Old Coot?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 11-17-2013, 06:41 PM   #62
The Canadian Paul Anka
Old 11-17-2013, 06:50 PM   #63
You win the popcorn...
grayfox is offline   Reply With Quote
Old 11-20-2013, 07:06 PM   #64
Big Bad Allis's Avatar
Helpful Information and advice
I didn't read through every post on this thread. Oil topics get hot and crazy. The only real way to tel is to perform an oil analysis and use a good method to do it. I am a lubricant engineer and work with many automotive companies, including GM, Mercedes Benz, Porsche, Nissan, Kia and Ford to anme a few. You need to establish a baseline to really determine when to change your oil.
I recommend choosing the oil you think is the one you want to use. Mobil 1, SynPwr etc. At 3,000 miles on the drain pull out a sample and have it tested. It will come back fine and recommended to continue use. It will be flagged if there's anything abnormal. Next run out to 5,000 miles on the same oil. Compare it to the 3,000 sample. It will more than likely still be good for further use. Run again at 8,000 miles and repeat. You will be able to see when the oil is ready to be changed. The scary part is that some oils just hit a way and go from being reasonably good spec'd and drop off fast.
In the analysis you will see contaminants, such as soot, silicates (dirt), wear metals if any, water, fuel dilution. The company that provides the service can help you read it. Once you have fugured this out you will not have to do this every oil change. I recommend doing an oil analysis every couple of oil changes (only when you drain) not several times throughout the change. You will be looking for any abnormalities that can lead to a reduced engine life.
Diesel guys. If your doing this and don't have a fuel dilution problem the best indicator is to change the oil when the TBN and TAN numbers are close to the same number. TBN starts out typically from the 9.5 - 13 range and TAN an 0 (zero)
Here's a very trustworthy company the we use. You can mail in your sample from anywhere in the country.
Petroleum Technologies
Petroleum Technologies Group L.L.C.
Jason
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 11-20-2013, 07:14 PM   #65
TURBS's Avatar
Jason
As I stated previously I am going to start some oil sampling with my next oil change.
I get the sample kits from my oil distributor as we sample our fleet several times a year.
Turbs
Old 11-20-2013, 07:49 PM   #66
BBA, check my post #36, not a lube engin but spent time in college, ~1968 working in the gas turbine lube research group with RDS. The test I mention was done as a regular spot test and was a great predictor of test evaluation of both bearings and oil analysis.
We did a recip engine test with syn oil and got bored tearing down, evaluating, re-assembling and going through the cycle with no deterioration of either engine or oil. Due to the cost at that point we made a syn/dyno blend with much the same result. Oil tech has gotten so much better I have no reason to consider syn in any engine not in continuous service.
jmo
Timtation is offline   Reply With Quote
Old 11-20-2013, 07:55 PM   #67
Turbs
Excellent idea. Maybe you can get them to throw you in a freebie for your personal vehicle since you run your fleet through them as well as purchase your oil from them.
Jason
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 11-20-2013, 08:28 PM   #68
Not to derail this thread but guys who have the 2007.5 and up Duramax's what kind of fuel milage are you guys getting? I'm contemplating a switch to the dark side but have been reading the newer models suffer a pretty good hit in fuel economy over prior years.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 11-20-2013, 08:50 PM   #69
RKR
RKR's Avatar
I have an '11. No mods , 4x4, stock tires, 3/4 ton. I get 17.5 to 18 empty at about 80. I pull around a 10k 5ver and get 10 to 11 between 65 and 70 with just a few hills to pull. No mountains. I got plenty of power to spare too.
I really like the Allison trans and engine brake. You can't get either in a gasser.
RKR is offline   Reply With Quote
Old 11-20-2013, 08:52 PM   #70
TURBS's Avatar
Totally stock 08 duramax.
17-19 hiway unloaded in the summer
15-17 hiway unloaded in the winter.
9-11 towing 14, 000# 5er.
Turbs
