08-11-2016, 10:37 AM
GMC 2500HD Transmission cooler
H i Folks
I just bought a brand new GMC 2500HD with towing package. I would like to install additional transmission cooling, preferably one with it's own fan. Anyone done this so far? If so which one did you use and where did you put it?
Thanks Eric
08-11-2016, 10:52 AM
Is this in diesel or gas?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
08-11-2016, 10:54 AM
Not on any of my trucks, but I've put this on a couple jeeps I've had.
Mounted behind the grille.
http://www.speedwaymotors.com/Derale...Kit,53658.html
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Bring Back The Search!
2017 Dynamax Isata 4
08-11-2016, 11:06 AM
Gas
08-11-2016, 11:18 AM
Georgia Rally Coordinator
No reason to add one. The one that comes with the truck does an excellent job. I've never had to add an additional one to any of the newer Chevy 3/4 or 1 ton trucks that I had. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-11-2016, 12:36 PM
I tow a 10K trailer with just the installed transmission cooler. I added the transmission temperature to the digital display to monitor it's temperature. Try that to determine if you need additional cooling.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
08-11-2016, 12:38 PM
My 2012 Chevy with Duramax/Allison combo seldom hits 165 with the factory cooling even pulling long grades towing.
08-11-2016, 12:43 PM
Agree. Ran ours recently with outside temps of 100 and the everything stayed fine, but we did stop more often at rest areas to let tires, bearings and oil temps cool a little. Had the time and the brief rest did us good.
08-11-2016, 12:48 PM
What are you towing? and where are you towing? Im sure it can be done but why are you adding another/extra one?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
08-11-2016, 01:17 PM
5 Stat Tuning
I have a 2015 Georgetown 335 with a Ford V10 I was wondering Who might have used it and the good and bad about it. I am new to the forums
Benny Chaney
Oklahoma City,OK.
08-11-2016, 01:27 PM
I really cannot see the need for the extra tranny cooler. I have a 2015 GMC 2500HD gas with the tow pkg and the cooler on it works great. Pulled my unit up 7,8 and 9% grades when out West last year and not once did the tranny get overheated. When u switch to tow/haul mode your gauges change and u get a transmission temp gauge also. I would try it first before putting a lot of $$ into something u really do not need. IMHO
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
08-11-2016, 02:47 PM
Transmission cooler
I would recommend a PPE (Pacific Performance Engineering) tranny cooler. I installed one on my 2005 2500 HD Duramax. I've noticed a significant change in the transmission temps ( around 25-30 degrees) when towing. Regular city driving the temps equalize to the engine temp. I live in Colorado so mountain driving is a test for the truck. I'm towing a 23' XLR toy hauler with a Harley touring bike (FLHTK) and at times a 20' Cargo Mate enclosed car trailer with a 69 Mustang in it. There are several after market coolers for your truck. PPE is a bit more expensive but IMO worth the money.
08-11-2016, 02:51 PM
In your case with a 11 year old truck yes you may need it but newer trucks do not require an additional cooler unless your trying to tow more than the truck is designed to tow. Spend your money on travels Later RJD
Days camped 2019 62
08-11-2016, 03:16 PM
That doesn't seem right.
08-11-2016, 03:47 PM
It's not.
That a non towing temp.
Pulling my snowmobile trailer in 0 conditions mine reached 170-180 degrees
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
08-11-2016, 04:11 PM
My 2015 Duramax pulling a 16,000# 5th wheel runs 125 going down the highway and only gets to 150 going up a mountain grade. No need for a additional cooler.
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
08-11-2016, 04:42 PM
Ok, sounds like I won't need it. We just bought the truck and camper will come in the spring. Just thinking ahead but we'll give it a go first.
2016 GMC 2500HD Gas
08-11-2016, 04:53 PM
Originally Posted by TURBS
It's not.
2015 Columbus 320RS
2008 2500HD Duramax
What do you mean by 0 condition?
I have a hard time believing these reports (not you) of 150 degrees with a 15,000+ trailer up the mountain.
I was pulling 11,000 lbs in 90 degree weather a few weeks ago. I was 190 in the flats and 210 in medium grades.
Seems like the numbers are very far apart. I know my factory trans cooler is pretty significant.
08-11-2016, 05:58 PM
I rarely ever even hit 150 degrees on my trans oil with my 2004 Silverado 2500HD while towing a 10,000 gvw tandem axle dump loaded with sand.
Never got to 160 degrees when I used to tow that 98 FR Wildwood 26' 5er.
but I live in Michigan and rarely ever had to drive in 100 degree heat.
So, yes that 160 degree mark can be correct
08-11-2016, 06:13 PM
Just in case you still want to, even if not needed. Never enough money, horsepower, or time off work so why not too much cooling.
I like the fan for this reason. Install it on a switch and you can run it for a short while after towing to simply throw air over that hot engine and it components. Why not that's my logic.
So this one it a MITSIMOTO. they are a USA company in DE. Just over $ 100.00 on line. Very happy with mine
