Old 11-26-2013, 12:48 PM   #1
GMC/Chevy owners with Integrated Brake Controller - Is this normal?
Howdy.
My current setup is a '13 GMC 1500 Denali and a 2014 Stealth 1913 Toy Hauler that weighs between 5600 and 7700 depending on load.
The truck has the Integrated Brake Controller and I have tried to set the gain per the owners manual. Part of that process requires manually applying the trailer brakes using the controller only and setting the gain so the wheels lock up, then backing it off slightly. Even with an empty trailer, fully applying the trailer brakes from the controller will only slow us down a little. I can not get the trailer wheels to lock up.
Also, when towing, I don't get that familiar feeling of the trailer brakes engaging when I push the pedal - but the brakes are being applied. Stopping is smooth, the truck stays level and I feel 100% in-control at all times in normal driving conditions. I haven't had to make a panic stop yet.
I have the gain set around 8 (out of 10) - much higher and I can lock up the trailer pretty easily using the brake pedal. This seems high to me, given the relatively light trailer. I've had the trailer checked by the dealer and they said the trailer is fine.
I've towed small cargo trailers (for dirtbikes etc.) using an aftermarket controller in my prior truck (Tacoma) and I'm used to feeling the trailer pull when applying the brakes. I'm also used to being able to fully lock up the trailer wheels with a squeeze of the the afteremarket controller.
Is this the way it should work with the Integrated Brake Controller, or is there something potentially wrong with my setup? How can I check? Should I be concerned that I can't quickly stop the truck and trailer using the ITBC only?
Thanks!
vocoder is offline   Reply With Quote
Old 11-26-2013, 01:00 PM   #2
I'm no expert but I think something is off.
I can set my ITBC to 5, put it drive and give it a little gas, and when i squeeze the levers on the ITBC my truck and trailer come to an immediate and complete stop with my foot completely off the brake pedal.
Thats towing a 6500# tt
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 11-26-2013, 01:33 PM   #3
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
vocoder: I had a 2010 F150 pulling a 4,500 lb TT and had exactly the same problem you have. Took the truck to the dealer and they said that the ITBC is designed to react to the amount of load and conditions and nothing was defective. Like Bryan said, if I squeezed the levers I could lock the brakes, but did not seem to do the same when increasing the gain and hitting the brakes hard. The TT seemed to always stop well and I never had any issues that would cause me to think that the brakes were not working. I forced a couple of panic stops too. Can't say if your situation is unsafe, but it's sounds just like I had.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is online now   Reply With Quote
Old 11-26-2013, 01:47 PM   #4
jevanb's Avatar
will it lock at a stand still?? I had this same problem with my 5er, found I needed bigger mag`s, and larger wire from the box at the pin box on back, I also got rid of the Proportional brake controller (P2) and went with a timed base. now it is night and day, fought with the dealer and the factory for 1 year and then I said screw them.. pull your rotors and see if grease made its way into your pads and adjust the pads.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 11-26-2013, 02:51 PM   #5
Yes, if I squeeze the controller and take my foot off the brake pedal while stopped, it will hold.
Just me, my girlfriend and our crazy Boxer Stella.
'13 GMC 1500 Sierra Denali, '14 Stealth SS1913, '08 YFZ450 with some crazy engine mods.
Old 11-26-2013, 03:11 PM   #6
AquaMan's Avatar
The internal brake controller is working as it should. You're not feeling that big pull against the truck, because you're probably not trying to stop hard enough. My '11 and '13 both stop flawlessly with 14k 5er set at 7.5. I never feel the trailer tug or pull against the truck when doing a normal stop, but it will stop in a hurry in an emergency situation. It will also apply the brakes if the truck senses fishtailing.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 11-26-2013, 03:35 PM   #7
Agree with Aquaman I think your brake controller is working as planned. If the brake controller is not worker in 100% the brake working light would come on, that is what mine did when the module failed.
My 07 GMC displays a bar graph in the dash when trailer breaks are applied. The more break pedal I use the higher the graph goes. It did take a while to get use to from the add on controllers. Something to note I had to power stop on the interstate and I was able to go from 60 to 0 in a acceptable distance, not sure an add on controller would have stopped me.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 11-26-2013, 03:44 PM   #8
TURBS's Avatar
I concur with aqua boy....
But.... I would defiantly make sure your trailer brakes are adjusted up properly.
Turbs
Old 11-26-2013, 05:08 PM   #9
AquaMan's Avatar
Originally Posted by f1100turbo View Post
I concur with aqua boy.... But.... I would defiantly make sure your trailer brakes are adjusted up properly. Turbs
Who you callin' boy, youngster?
Old 11-26-2013, 06:28 PM   #10
TURBS's Avatar
Untill your as old as gramps ur a pup yet!
:roflblack
brake control, controller, brakes
