05-05-2009, 11:25 PM
GMC Yukon XL Denali tow
Hi all, I am totally new to camping. We are looking at purchasing a 2001 Wildwood Camper 27BH. I am just wondering if we can tow it or not. I have a 2004 Yukon XL Denali. Our max towing capacity is 8000 and I am unsure of the weight of the 2001 camper. The seller has not gotten back to me with that info. On the website the '09 version (which is not the same) is GVWR 7615 and dry ship weight of 4857. Which number do I go by? The 7615 is really close to my max of 8000. Thanks for any help.
05-06-2009, 12:09 AM
you should go by the gvrw
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
05-06-2009, 12:42 AM
Thx for the help chevy02. I was just on the NADA site and it said that the 'weight" was 5210 of the 2001 wildwood but I am not sure if that is dry weight or gvwr. Is there any website that I can go to that will have the weight of that year instead of the '09?
05-06-2009, 01:51 PM
Your gvwr is on the weight label on the front of the trailer. Just add the 2 axle weights together.
David
Devils Tower 2008
The Hunts
99 Tahoe 5.7L; 3.73; Tow Pkg; 2nd Tran Cooler; Towing Fan Clutch;
Throttle Body Spacer;Fram Air Hog Air Intake; FlowMaster SUV 50;
MGSCustom ECU tune [ new HP rating of 300 ]
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
10-14-2009, 11:39 AM
Rookie
Rather than start a new thread, I'll piggy back on this "dead" one. I also have an '06 Yukon Denali XL (6.0l AWD). Tow ratings are 7900lbs trailer, 600/1000 with WD tongue weight and 14,000lbs GCVW.
However, I have weighed the truck at 6360lbs with all passengers, leaving me (if I understand it right) with about 7,600lbs trailer weight.
We're seriously considering a 2010 Rockwood 2701SS. Weights are 5593 dry as equipped(directly off the inside-trailer sticker), 602lbs tongue weight (advertised) and 6666lbs GVW.
Will this combo be safe/effective with an Equ-i-lizer or a Dual Cam set-up? We will be towing into the Rocky's occasionally.
Thanks in advance and I'm glad to be here.
12-21-2009, 10:43 PM
I had almost the identical set up. 03 Denali with an 94 27BH. The Denali pulled it better than my 03 1500HD, the Air Ride suspension was awesome.
You should be fine.
12-22-2009, 08:18 AM
Grape Escape
You will all be fine with the Yukons. No matter what tow vehicle you have if you don't have hitch set up properly you can run into problems. Gross weight rating is max that that trailer can weigh when fully loaded which one hopefully never gets to.(Keep the lead out)
2008 Cardinal 30RKLE 5th wheel XPS tires
2009 Ford F250 CC 4x4 V10 Reese Signature 18K 5th
55 nights 2009
53 nights 2010
44 nights 2011
08-10-2010, 08:02 PM
Reviving the dead thread again. Input from Denali owners requested. I am considering trading up from my 2002 Suburban 5.3 to a 2007 Denali XL 6.2 my concern is the 6.2 and how it is holding up mechanically. I have considered other offerings from ford ect. but still need the 6 passenger, 2 dog and guinea pig loading ability of the XL/Suburban type SUV. My trailer is a Flagstaff 831QBSS 2008 with a tongue weight of 1100lbs by manufacturer specs. Yes I load more to the rear of the TT.
08-11-2010, 04:47 AM
I towed with a 1997 GMC Suburban with a 5.7 engine, auto trans with a 4:10 rear and there was no problem pulling a 2006 8314SS Rockwood, you should be fine.
08-11-2010, 12:36 PM
I have an '08 Denali with the 6.2L and have just over 20K miles on it and have not had any issues with the engine. Any issues I've had have been small fit and finish items (squeaks/rattles). Looking at moving up to new 2500HD though in anticipation of UltraLite 5er. Thus far towing my 2501ss has been decent with the Denali...I've driven a friends Tundra with their equivalent length, albiet heavier, trailer and the Tundra is a bit stiffer/more controlled
Tom
2010 Rockwood Ultra-Lite 2501ss
2008 Denali XL - 6.2L
Equalizer 1000/10000 Hitch
Nights camped in 2011 - 24
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 416 |
| 66 members and 350 guests |
| 13Dano, amxpress, benjornada, bikendan, bird_dg, Born2.wander, brookside, Buffalohunter, buzzmonster, campdohbrew, camper1953, caper, captain-fire, cbvp, cfsoistman, Crusader, dc31bhss, DDC, dnaraG_1M, donn, Elanpottery, Emptypockets, F.R.O.G., f1100turbo, fonzie, frankm, gene17847, grhodes50, Hob, Homey55, huricane, Itsthetwoofus, JAJ73, jdudd, JFM-jr, jojo bamboo, JWEAGLE, KarenS144, Larryvsr, LFugate, muzbomb, nailit, NorminN.B., Oakman, Old car, ParrotHead, PrairieBoy, reinerka, Rest and Relax, ret2006, rgmiller32, RubenZ, Shasta1, smcneil, smithmdsmith, Steve7575, tedstr, tetsurvivor, TheSasks, thewren, tmmar, Triguy, vcarbona, wbillar, weiman1983, Wildwood Danny |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
