Old 10-13-2016, 08:08 AM   #61
Coachman 312BHDS
tbln930's Avatar
I have a relative that had a mid 2000s (maybe 2005) Dodge with Cummins and I will never forget his rants about it. I never paid attention to what the problems were back then but he learned to hate it.
Originally Posted by Taranwanderer View Post
About the biggest "horror story" you'll find about the Cummins engine is with the VP44 high pressure fuel pump going bad. As someone who went throught it in my old Ram--this happens because Dodge and Cummins couldn't agree on where to put the low pressure lift pump--Dodge wanted it mounted on the back of the engine for ease of assembly, and Cummins repeatedly kept telling them "no, it needs to go in the tank where it's cooled by the fuel and won't be subjected to the heat and vibration of the engine, causing premature failure." Guess who won that argument? So when it goes bad, the VP44 winds up getting no help from the dead lift pump and has to suck fuel all the way from the tank, which it will do for a little while, but wasn't designed to do at all, hence the expensive failure. So if you have a Cummins Ram and the lift pump hasn't been relocated to the tank yet (or replaced by a good aftermarket one,) do yourself a favor and do it ASAP...
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
tbln930 is offline   Reply With Quote
Old 10-13-2016, 09:13 AM   #62
KenHwy61's Avatar
Originally Posted by tbln930 View Post
There are forums loaded with horror stories on Cummins engines. They are generally good but certainly have their own major problems.
I am on a Dodge/Cummins forum everyday and have yet to hear about a single engine failure horror story. In fact, the 5.9/6.7 Cummins engines are well known to run 500,000 miles and more. The guy just bought a new truck and we should be happy for him instead of being so critical.
Aviator Wright-Flyer#1908
1996 Holiday Rambler
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
f150
