Old 08-21-2016, 03:31 PM   #31
Coolharts's Avatar
LT tires in the 15" range do not have the load capability of an ST load range E Maxxis trailer tire.
Goodyear Wrangler SR-A Tire, P225/75R15:
•Treadwear warranty: 50,000 miles
•The traction tire is for light trucks/SUVs-on/off highway
•Specific sidewall style: outlined white letters
•Speed rating: S
•Load index: 102
•Speed rating translation: 112 mph
•Load index translation: 1874 lbs.
•Zig-zag microgrooves offer enhanced traction in rain, snow and ice
•Wide circumferential grooves help move water away from the tread for enhanced traction in rain.
•Goodyear snow tire features exclusive wet traction compound that helps provide traction on wet roads
Product Line:
Maxxis M8008 ST Tires
Summit Racing Part Number:
MXX-46119
Tire Size:
225/75-15
Wheel Diameter:
15 in.
Sidewall Style:
Blackwall
Tire Construction:
Radial
Tire Diameter Range:
28-28.99 in.
Tire Diameter:
28.30 in.
Section Width:
8.90 in.
Tread Width:
8.75 in.
Minimum Recommended Wheel Width:
7.00 in.
Maximum Recommended Wheel Width:
8.00 in.
Directional:
No
Load Range:
E
Asymmetrical Tread Pattern:
No
Tread Depth:
9/32 in.
DOT-Approved:
Yes
Tube Required:
No
Tread Ply Quantity:
10
Max Load Single (lbs):
2,830
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2015 Palomino Puma 30FQSS --Traded--
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27
Coolharts is offline   Reply With Quote
Old 08-21-2016, 08:32 PM   #32
Airdale's Avatar
•Speed rating: S
•Load index: 102
When used on RV trailer axles or a pick-up truck that load index (1874) MUST be reduced to 1703 lbs..
There are no UTQG codes for LT & ST tires.
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 08-21-2016, 09:03 PM   #33
CaptnJohn's Avatar
I have 16" wheels but would need 4 axels for those to come close to my needs.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-21-2016, 09:04 PM   #34
If you buy Marathons, plan on this happening!Click image for larger version
Name:	ImageUploadedByForest River Forums1471827849.670098.jpg
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 08-21-2016, 09:07 PM   #35
CaptnJohn's Avatar
Originally Posted by garmford View Post
If you buy Marathons, plan on this happening!Attachment 118042
That is ugly! Hope everyone was OK and no damage to the trailer.
2016 F350 diesel
Old 08-21-2016, 09:27 PM   #36
Airdale's Avatar
Look closer, that's not my original post, just a quote about Coolharts post.
USN - RET - PDRL
SSA - RET
Old 08-21-2016, 09:43 PM   #37
toslow's Avatar
How old was that tire? And what was the circumstances of the failure
haven a blast
toslow is offline   Reply With Quote
Old 08-21-2016, 09:54 PM   #38
Speed Rating
Newer tires are rated for 81 mph instead of 65. Make sure whatever tire you buy is rated for 81 mph. I upgraded all of 11 of my trailer tires to 81 mph tires, and I haven't had a flat since. Taskmaster tires from etrailer are M rated for 81 mph, although the only place they state that is in the video for the tires. Get the highest load rating you can, because most tires are close to max rating on most trailers, and by the time you load all your junk in it, you're probably over weight.
mnoland30 is offline   Reply With Quote
Old 08-21-2016, 09:58 PM   #39
Those tires had roughly 3000 miles on them and only 2 years old. We were just driving down the interstate when it blew. I felt a slight tug while driving, I looked in my mirror to look to change lanes when I saw all of the shrapnel flying out from both side of the camper. Of course there were orange barrels as far as we could see so I dove in between two of them to get to the shoulder of the road to change it out. Thank God it was on the passenger side. A few months later I replaced all of them. The tire shop showed me that another tire had broken belts and was ready to blow next.
Name:	ImageUploadedByForest River Forums1471830857.972196.jpg
This picture is the wheel well. Not much to it, just a layer of that black plastic covering some 1/4" luan. And if you look close enough you can see the water lines that were above. I always laugh when people want to live in their camper in the winter!
Name:	ImageUploadedByForest River Forums1471831058.994098.jpg
Tore up,the fender skirt too.
Blue Ridge 3710 BH
Old 08-21-2016, 10:18 PM   #40
Coolharts's Avatar
It appears LT tires will work for 16" wheels but not for 15" wheels, I know my TT will be over the 1703 lbs per wheel.
tire, tires
