Old 12-06-2016, 11:08 AM   #11
Originally Posted by DreiHunde View Post
Light coat of spray lithium. Hitch works great.
For what? Youroo! !
Old 12-06-2016, 11:21 AM   #12
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by youroo View Post
For what? Youroo! !
The ball and socket/head surfaces....and the slide out gear track and the stab jack screws and mower deck mechanism and...
I do wipe the brackets and bars down after towing with the greasy rag I've used to keep them clean. But the amount of grease on that friction point is negligible.
When the hitch makes noise it means it is working.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 12-06-2016, 03:15 PM   #13
dmlranhc
Definitely do not grease the friction bar, as that is your sway control. Grease only where the bar connects to the hitch. Clean off the grease from the friction bar other areas, Dawn dish liquid would do well.
dmlranhc is offline   Reply With Quote
Old 12-06-2016, 04:23 PM   #14
My Blue Ox has grease zerks . Must be there for a reason.
Japalilo is offline   Reply With Quote
Old 12-06-2016, 04:28 PM   #15
Blue Ox is not a friction based hitch. Most if not all spring bars need grease at the hitch head, but not where they meet with trailer A frame.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 12-06-2016, 04:38 PM   #16
Well there you go.
Old 12-06-2016, 04:53 PM   #17
My WDH has grease fittings, so I grease it, never had a problem with sway.
D-Man is offline   Reply With Quote
Old 12-06-2016, 04:57 PM   #18
Mrs.Kay's Avatar
I knew you good people would have the answer.
I am not losing my mind hehehe, I DID read somewhere NOT to grease the friction point on the bars.
Done. Grease cleaned from the sway bars.
Thank you Rockfordroo for the link.
THANKS TO ALL OF YOU for your knowledge
XOxo Mrs.Kay
Mrs.Kay is offline   Reply With Quote
Old 12-06-2016, 08:45 PM   #19
Originally Posted by rockfordroo View Post
You're right, I thought she was talking about the bar hinge points.
That being said, Equalizer does make these for the L-brackets:
They're called Sway Bracket Jackets. I have a set and they quiet the hitch down very well.
Equalizer does note these will reduce the friction and sway control and should be used if you have severe swat issues. I use them on mine, albeit overpriced.
CedarCreekWoody is offline   Reply With Quote
Old 12-09-2016, 12:23 PM   #20
Filterman's Avatar
I can't speak to a Fastway E2, but Equalizer says to lubricate.
See figure #23 on pg 23 of the attached PDF.
UPDATE:
The E2 manual also says to lubricate. See Step 10, fig 19, page 21.
http://www.fastwaytrailer.com/wp-con...tions_0212.pdf
I smiled when I read the part " Do not tow your trailer on rough roads". Guess they would have frowned on our Arctic Ocean trip with 1600miles of gravel road last summer! 😄
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights
2016 96 nights .2017 72 nights. 2018 157 nights
Filterman is offline   Reply With Quote
hitch, weight, weight distribution hitch
