Old 03-22-2018, 06:50 PM   #1
Grey wolf 23 mk towing
Ram 1500 5.7 hemi quad cab 3.21 8 speed. Ran the numbers seems ok not great but ok . Will be just the wife and I ,no water and dont plan on any big mountain travel etc... any tnoughts just upgraded from 4000 lb trailer to the grey wolf .
Vaughan is offline   Reply With Quote
Old 03-22-2018, 08:18 PM   #2
I have your same truck and I pull a FR Cherokee that is 6200lbs dry. all my numbers are within limits. I use an equalizer hitch and a few other upgrades and it does perfect. LT tires are a must in my opinion
911Fire is offline   Reply With Quote
Old 03-22-2018, 08:29 PM   #3
You must be really searching out the weight police crowd if you have a 5.7 hemi and are worried about towing a 5k trailer. your truck is probably rated at twice that.
I towed an 8k pound 5th wheel with no problems with my ram 1500 before upgrading.
Kimber45 is offline   Reply With Quote
Old 03-24-2018, 06:33 AM   #4
Payload is the killer on the half ton Ram's. Mine was only 1099 lbs, check the door sticker.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 03-24-2018, 08:18 AM   #5
Interesting - I am in a similar truck and the payload limit of 1312 lbs is what is killing me. I'm a newbie but on my post they are telling me hitch weight is going to be 10-15% of the GVWR of the trailer. The 23MK has a GVWR of 7608 so I guess that would be 760 - 1141 lbs added to you payload. Plus whatever the weight of the WDH??
paleopaul is offline   Reply With Quote
Old 03-24-2018, 08:20 AM   #6
But then you see a lot of this sort of thing and I wonder if I am perhaps overthinking and over-interneting this whole thing? Real world experience and all that.
Old 03-24-2018, 08:26 AM   #7
Specs show dry hitch weight of 608 so you'll probably be around that 760-800 range. I think you'll be right at the edge but your truck should be fine.
2013 Rockwood 2109S
Old 03-24-2018, 08:54 AM   #8
Flybob's Avatar
What does the yellow sticker on the drivers door jamb say the payload capacity is?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-24-2018, 08:56 AM   #9
He said 1312 lbs in an earlier post.
2013 Rockwood 2109S
Old 03-24-2018, 09:05 AM   #10
Flybob's Avatar
Only see one post by OP and no payload mentioned.
TST Tire Monitors
2 100W solar panels
Old 03-24-2018, 09:07 AM   #11
Without a quote I had no idea who you were asking that question to. I assumed the most recent poster.
2013 Rockwood 2109S
Old 03-24-2018, 12:02 PM   #12
Just because someone tows overweight and says all is good doesn't make it right. Anyone with a small calculator could punch in the numbers and see he's was overweight.
goduc is offline   Reply With Quote
Old 03-24-2018, 01:36 PM   #13
I have a 2018 23MK and tow with a 2011 Ram 1500 4WD, 5.7Hemi Quad cab with Trailer tow equip, I do not go to mountains but have towed it in NC , SC with no problems
Bob Johnston
2018 Grey Wolf 23MK
2011 Ram 1500, Big Horn, Hemi, Quad Cab, 4X4
bobj6293 is offline   Reply With Quote
Old 03-24-2018, 03:22 PM   #14
Mine is a 2017 and the payload is 1542 lbs. Yellow sticker on pillar says combined weight of passengers and cargo should not exceed 1542 lbs ? I'm assuming this is payload . Picked up the trailer today and it towed good a little pull when being passed but lots of power and was around 2000 rpm on Hwy doing 60 mph.
Old 03-24-2018, 03:26 PM   #15
My TRUCK is only rated to pull 8000 lb trailer so I would not want to pull anything heavier . Safety is my main priority . And not being stressed when on vacation . I have seen several 5 th wheels being pulled by 1/2 tonnes and it isn't pretty
grey wolf, towing
