Old 05-30-2014, 02:33 PM   #11
Disconnect the vac lines at both front knuckles and plug them with golf ball tees,use a vac pump and apply vac to the outlet port of the vac solenoid for the hubs(located behind the battery)should hold vac-if not replace all the vac lines from the solenoid to the hubs-these are known to get pin holes in them.Check the vac check valves to see if they hold vac in one direction-if not ,replace the vac check valves.Vac test the vac reservoir,it should hold vac-if not replace the reservoir(located under the battery box).Also,with the hubs ratcheting,there will have been damage to the actuator and hub teeth,so replacing those parts were not money wasted.
Hope this helps with your diagnosis.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 05-30-2014, 09:16 PM   #12
Truck is now repaired. Dealer found a broken vacuum line. Thanks for all the advice. If I ever have the problem again I will know how to fix it myself.
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 05-30-2014, 11:53 PM   #13
TURBS's Avatar
I wasn't so far off eh?
TURBS
"Sabre owners united"
Old 05-31-2014, 05:56 AM   #14
Retired Trucker/43 years
Noneyerbusiness's Avatar
While we are speaking of Ford F-150's ..... mine has a "chatter" when starting with trailer attached, much worse on a slight incline. Dealer here said they chased that problem on a F-250 until they found the actual driveline is a bit out of alignment when loaded. The owner insisted they fix the problem. When repairs were completed, the chatter was there when it was empty! They advised me, and I agreed, the minimal chatter I received on start up was better than having it all the time empty!
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
