06-18-2012, 11:44 PM
GVWR and GCWR question...pls help....confused
Ok, so here it goes, while researching alot of different rigs and my TV specs and limitations as question has arose to which I am extremely confused, might just be me, but hopefully someone can shed some light for me....
My TV is a 2012 Ford F350 Crew Cab SRW 6.7L Powerstroke with FX4 Package.
(not looking at the stickers right now but weights listed are pretty close)
GVWR 11,500 lbs
Cargo not to exceed 3460 lbs.
So my estimated curb weight is roughly 8000 lbs.
My new rig is a 2013 Sierra 365SAQ with a GVWR of 14k lbs, tongue weight of 2100 lbs and and dry weight of 12k lbs.
According to Ford, with my truck configuration in the tow manual, my truck can tow 15,700 lbs with a properly fitted fifth wheel hitch.
The part that is confusing the hell out of me is that the same Ford Tow guidelines state the GCWR is 23,500 lbs.
How do they come up with this figure?
If I am fully loaded at 11,500 which I wont ever be but still, and tow a fully loaded trailer to their specs of 15,700, shouldn't my GCWR be 27,200 lbs?
My trailer is only 14k loaded and i dont anticipate truck being anywhere near max as all will be in the trailer besides the wife and kids. (of course i will watch weight by towing empty grey and black and maybe a few gallons of fresh for bathroom usage) so I do not anticipate being close to the 14k lbs either....so I will be 1k-2k below the GCWR listed but just confused on how the numbers work.....
Can anyone shed any light?
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
06-19-2012, 12:05 AM
The maximum towing weight of 15,700 lbs also includes any payload carried in the truck. Working backwards GCWR of 23500 - max tow of 15700 lbs = 7800 lb truck.
Dave
06-19-2012, 12:24 AM
Thanks, I got the idea now......so looks like i am well within my ratio......I cant wait to pick up my new rig in 2 weeks
06-19-2012, 03:08 PM
I must be missing something? If your truck is 9,000 lbs ready to go and you have pin weight, empty 2,100 lbs, it will be almost 20% of loaded 5er or near 2,800 lbs, when they are put together, you have 11,100 or 11,800 lbs for the truck and take that away from 23,500 lbs you will be able to pull 12,400 lbs or 11,700 lbs. I have the same issue, truck 2011 F250 can pull a 5er of 16,200 lbs and my combined, GCWR, is same as yours, 23,500 lbs. Truck is 7,500 lbs ready to go and my 5er is 9,850 ready to go, so truck plus pin weight of 1,900 lbs is 9,400 lbs and 5er at 9,850 lbs comes to 19,250 lbs much less then the 23,500, but the truck is close to the 10,000 lbs limit.
06-19-2012, 03:25 PM
The weight he can pull using your numbers of 11700 to 12400 would be the campers axle weight.
If you concluding that you reach the payload or GVWR limit of the truck before the maximum towing limit...yes you're correct. That would be true whether half, three quarter or even one ton truck when towing 5th wheel campers.
Dave
06-19-2012, 04:08 PM
Ok so now im confused as hell again LOL
06-19-2012, 04:22 PM
AKA Bluebird
Neither the truck nor the trailer can exceed its individual Gross Vehicle Weight Rating rating when not connected. The Gross Combined Weight Rating (when they are hooked up and ready to travel) is the maximum that the loaded truck and trailer may weigh if you put them both on a scale at the same time.
1) Do not exceed the G Vehicle WR of either the truck or the trailer.
2) Do not exceed the G Combined WR of the truck.
06-19-2012, 04:29 PM
Ok, im good there....thats not an issue, just seems like with the math I am seeing is that the king pin is double tipping the numbers up.
I.E. 9000 lbs ready to roll truck and 14k lbs trailer =23,500 lbs
but if you add the 2500 to the 9000 for the kingpin weight in the truck, shouldnt some weight be off the trailer thus making it less then shown.
Im just reading it as a 14k trailer fully loaded has 2800 lbs of that weight going into the bed of the truck, thus making the trailer weight much less than 14k but increasing the weight in the TV.
Sorry if i seem stupid about this, just confused because it seems to me you add 2800 lbs loaded to a TV but it still shows on the other end of the trailer too, making an appearance of a mysterious 2800 lbs.
AKA Bluebird
Reframe of 1 & 2 above.
1)The truck can only weigh so much before its tires pop. Same for the trailer.
2) The poor little motor in the truck can only move so many pounds before it sputters to a stop and goes to engine heaven.
06-19-2012, 08:12 PM
AKA Bluebird
Let's see if this helps. If the weight on the kingpin is considered as part of the load on the truck does that mean you can add the kingpin weight, now being carried on the truck, back to what can be carried in the trailer? Though the following is just the way I have it figured out in my own head, my answer to that question is no.
A trailer is composed of many subsystems, such as tires, axles, frame, kingpin box, tank placement, etc. The subsystems are designed/rated to work in harmony to create a system (trailer) that works safely when being towed. The manufacturer crunches the numbers and determines that all the subsystems (with all the stresses that will be placed on them when the trailer is being towed) will play together nicely and that all will be well as long as the trailer, unhooked and sitting still on a CAT scale, weighs no more than x number of pounds. In making this determination the manufacturer is well aware that the weight of the kingpin will be on the truck, and includes that in the calculation. The number that results is the GVWR of the trailer.
Using this model I was able to resolve the issue to my satisfaction. All I had to do was convince myself that the GVWR is calculated based on the trailer being on the ground - and not assuming that it was calculated when the trailer was hooked up.
06-19-2012, 08:21 PM
Ok...made perfect a sense now....im going to weight my truck tommorow with fuel to see where i actually sit at....but since i tow dry.....i dont anticipate more than 12,900 in transit....plus my approx 10k truck with kingpin i should be good....thank you for the break down
06-19-2012, 08:23 PM
Saw another one on here towing with an F250 but he put air bags and an F350 springs in his rear.......says he has no problems at all.....so maybe i will add another leaf and bags to support just in case
06-19-2012, 09:09 PM
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
06-22-2012, 09:00 PM
My $.02. My gross limit is 24,500. My rig weight is just under 17,000. 17,000 divided by 24,500 is .693, in other words I'm at 70% of my allowable weight.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2021 Chevy High Country 6.6 gasoline
Hensley Arrow, best investment ever!
06-22-2012, 09:43 PM
You are at 70% of your combined weight rating. That figure has to do with pulling and stopping your combination with your engine, trans, rear and brake size.
It really does not tell you if your truck or camper is overloaded (individually) (ie exceeds their individual GVWRs).
If you add the GVWRs of your truck and camper it will be more than your GCWR.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-23-2012, 01:51 PM
Herc,
It's a Duramax, just about like yours only a little more ass in the pulling department. And it doesn't smell like a diesel, which I like.
BTW we are booked in Myrtle week of Labor Day, I would like to chew you ears off about flying, if you could make it.
Regards,
Mike
Mike & Lu Anne
06-23-2012, 07:03 PM
Herc,
Regards,
Mike
Mike, I assume since we are talking about "pulling" you mean like a donkey. I was looking at the 2011 and 2012 GMC 2500HD towing specs and I have to say you are right. OMG can they pull.
The major reason for the 23% boost in combined weight has nothing to do with engine, trans, OR gears. It is the smart diesel exhaust brake. Using the exhaust brake alone the test driver was able to slow and stop (with a brake tap) a 20,000 pound 5th wheel "test blivet." (steel sled)
2011 Chevrolet Silverado Heavy Duty unveiled, ready to take on Ford Super Duty - egmCarTech
sigh
TV envy....
06-23-2012, 08:49 PM
If you have ever gone down I-77 VA into NC, Fancy Gap. Going down set the cruise at 70 and it goes 70, never touch the brakes. Going north, my first trip up the hill I nailed it, I lifted at 75 and it went by 80. Now I set the cruise at 70 and hold it in 4th gear, 2600 rpms smooth as silk, see you at the top.
We went to Massachusetts last summer, passed this old bread truck proudly owned by current day hippies. On the back it said 'I burn veggie". It looked like they were burning ping pong balls, and here I'm driving about the cleanest burning thing on the road....
Mike & Lu Anne
06-28-2012, 10:11 AM
GVWR 11,500 lbs
GVWR of 14k lbs
GCWR is 23,500 lbs.
Most (not all!) tow vehicle provide the max tow rating only when the truck is empty with only a 150 lb driver. So:
Empty truck = GCVWR (23500) - Max tow rating (15700) = 7800 lbs. This is pretty close to your 8,000 lbs. So the numbers sound right.
Looking at your numbers, you are:
7800 (empty truck) + 12,000 (dry camper) = 19,800 lbs.
This does not include any passengers, or any cargo in either vehicle.
Also, is that 12k the dry weight (no options) or the factory shipped weight (including options). If options are not included, then you should expect to be right at 14k when loaded (be careful). If the shipped weight, you have room.
23500 - 19800 = 3700 lbs available for people and stuff (and camper options if not included in that "dry" weight.
06-28-2012, 12:23 PM
Thanks...12,282 is the shipping weight. 11,876 is dry weight. A bit of better numbers for the truck scaled today:
GVW: 8380 with full fuel and passengers (no hitch).....8580 with hitch we'll say.
GVWR: 11,500
RGAWR: 7000
RGAW: 3360 (w/o hitch)
RV: 12,282 shipping
GVWR: 14,082
Kingpin dry: 2100
