Originally Posted by cmysstailights
I am trying to see if i am gonna be over payload by a mile and trying to understand all this number stuff. Diff between a 2500 n 3500 are only suspension and rear axles.
2015 silverado 6.0 crew cab
Payload sticker 26xx
Gvwr 9500
Gawr rear 6200
Tires 3195 each
Trailer tt tongue weight approx 1200
Golf cart 1000
Passengers and some cargo 800
Truck has airlift 5000
Same brakes as 3500
I could put the approx. extra 200lbs cargo in the trailer.
I need new tires so gonna go to a 124 load rating tire.
Thx
Drew
If i take my gvwr minus my curb weight it comes out to 3850. But my payload is 26xx. This is where i am confused.
Somewhere you made a math error with your gvwr minus curb weight.
So lets take the 2600 payload number and subtract that from 9500. The answer is 6900lbs...that is how much your truck weighed when it left the assembly line. Anything the dealer added (running boards/bed liner/bed mat/undercoating/etc) and everything you added (airlift 5000/hitch/bed cover/bed rack/cup holder/bag of chips/humans) gets subtracted from the 26xx number or added to your trucks weight of 6900lbs...until you reach 9500gvwr. -There is no chance the 3000lbs (total from your list) added to your truck does not exceed your 9500gvwr.
The payload sticker on your truck (26xx) is your max cargo or max weight that can added. That amount will take you up to your truck's maximum gvwr of 9500lbs and no comparisons between 2500 and 3500 series trucks relating to axles, brakes or whatever is relevant on deciding if you are overweight. Using that comparison to make a weak justification in your mind for being over is another topic.
