Old 04-13-2016, 08:44 PM   #1
Have a few questions WDH on my New TV and Coupler Lock
Bought a new camper, you may have seen my previous post, "scariest ride home" towing with my Durango (rv salesman, no problem). So now we we and bought a new TV, picking it up tomorrow. I'm sure it will tow this time LOL! My question is, the truck is hight up, so, do I measure the top of the ball and then get the coupler on my new TV level with it, before hitching? WDH after that and do I need to worry about how much tongue weight is applied to the front axles still with this TV? Should I use on the one pro series sway bar, or get another?
And does anyone recommend a coupler lock for anti theft?
TV 2016 Dodge Ram 2500 6.4L V8 Hemi 3.73 axle, payload over 3,000 and towing capacity over just over 12,000b (big difference from that Durango)
TT 2013 PrimeTime Avenger Dry Weight 4088 GVWR 7785, 26feet long
I don't know the tongue weight, never made it to weight station, does that matter at this point? Thank you. I'm learning thanks to all of you
DebMar is offline   Reply With Quote
Old 04-13-2016, 09:35 PM   #2
Weigh station matters; get loaded up to camp, with the people you will be camping with, and go straight to the scales; don't forget to have a full fuel tank. It helped me really understand what was going on with my entire setup. This will be particularly useful not on the calm, normal, no issues day... This is for peace of mind on the heavy traffic cross wind day, knowing I did what I needed to do.
2016 Rockwood Sig. Ultra Lite 8312SS Platinum
2016 GMC Sierra 3500
Equal-i-zer 10K WDH
Tadi Brothers 9" Wireless 120 degree Rear Cam
2015 Nights Camped: 4
2016 Nights Camped: 8
hazmat91180 is offline   Reply With Quote
Old 04-13-2016, 09:48 PM   #3
The owners manual for the new truck should have info on trailer towing and how to set up the WDH as it relates to front axle weight. The hitch manual should have info on the measurements to set the ball at the right height. I use a DT25013 coupler lock.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-13-2016, 10:26 PM   #4
Broadway Joe's Avatar
Congratulations and good luck with your new truck. I am not familiar with your wd hitch but all should follow certain guidelines. I would level your TT and measure from the ground to the top of the receiver cup. Then set your ball height on your truck to the same or slightly higher, I would not go more than an inch or two. After all this is setting up your weight distribution bars for proper weight transfer to correct for any front fender lift - rear sag.
Hope this helps
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 04-14-2016, 05:06 PM   #5
CaptnJohn's Avatar
With your payload and towing capacity I'd not bother going to a scale, but that is me. Sounds like you should have over 800# excess payload and a lot of tow capacity left over. Level the trailer, set the hitch up correctly and you should have as comfortable tow as possible with a TT.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-14-2016, 08:05 PM   #6
Weigh just for information and peace of mind if nothing else. Not knowing what you "don't know" is a worry sum place to be. With knowledge, you can make changes and know if you helped or hurt. I had to load, adjust, and weigh mine three times to get it right.
Happy trails!
pdqparalegal1 is offline   Reply With Quote
Old 04-15-2016, 11:34 AM   #7
The following link was submitted on the forum some time ago and it really helps. Congrats on your new TV.
If the link does not work look up equal-I-zer hitch on You Tube
James & Amy
2016 246RKS Freedom Exp.
2006 Toyota Sequoia
It's a nice night for an evening
woodpile is offline   Reply With Quote
