Old 08-06-2014, 10:13 AM   #1
Arefbee's Avatar
Have enough tow vehicle for the trailer
I am guessing this minivan did not have a tow package.
Newly purchased camper spared but van destroyed - Local - The Journal Pioneer
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 08-06-2014, 10:35 AM   #2
indybp57's Avatar
How hot would a tranny have to get to burst into flames?
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 08-06-2014, 10:52 AM   #3
Infractee
Most likely tranny overheated, started venting trans fluid directly onto the catalytic converter which immediately caused the fluid to catch fire?
RhoZeta is offline   Reply With Quote
Old 08-06-2014, 10:59 AM   #4
Take The Road Less Travld
MuddauberE's Avatar
At least the camper made it out safely!
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 08-06-2014, 11:14 AM   #5
jk510's Avatar
I wonder how big, or small, the trailer was that passersby were able to disconnect and move it.
Joel K
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 08-10-2014, 05:06 PM   #6
That's just a few miles from where we are camping right now!! I'll have to ask around to see if anybody has any more info.
2020 Flagstaff 26FKBS pulled by a 2019 F-350 Diesel
N3HCP is offline   Reply With Quote
Old 08-11-2014, 01:18 PM   #7
Had a similar experience with a Ford Windstar - predecessor to Freestar. Rented the smallest U-Haul covered trailer to move from California to Colorado. Van started smoking on grade up to Eisenhower Tunnel on I-70 (10K ft). Before I could get the rig completely over to the shoulder, the transmission siezed solid. Although my transmission fluid was venting over hot exhaust pieces, it never caught fire.
Sold the Windstar to a mechanic for $800 since my wife was never going to let us ride in that vehicle again.
FWIW, in Alaska I had a 1992 Ford Explorer. Was towing a 200lb aluminum skiff (total of 400lbs) 5 miles from Chicken, Alaska (population 32), over 100 miles to anywhere else. Transmission started slipping. Got out to check - fluid all over frame of trailer. I thought I had holed transmission oil pan. Hitch-hiked 5 miles to Chicken, where there was an Anchorage mechanic who spent his summers in Chicken. He said that transmission was notorious for blowing front seal under load, but that the seal was resilient enough to sometimes reseat itself. He sold me a case of tranny fluid, I filled the tranny (5 qts low). He said check it every 30 miles while I drove the 400 miles to Whitehorse. After the first few checks revealed very little leakage I lengthened my checks to about 50 miles. At the Canadian border, I asked the Canadian agent about any repair facilities in Dawson City, which was about 200 miles closer. I got to the recommended shop and they said the same thing - that Ford transmission was notorious for blowing front seal. They replaced the seal (last one on their shelves) for $400 Canadian ($300 US in 1999). After that, I always manually shifted the Explorer when towing - the transmission went over 100K miles with that new seal.
I will never tow again without adequate transmission cooling, although the Explorer was an internal pressure issue, not overheating like the Windstar was.
just my experiences - I'd prefer to learn from the mistakes of others instead of my own.
Fred W
Old 08-12-2014, 03:51 PM   #8
thebrakeman's Avatar
Must have been a popup camper if they were able to push it away. Any full-height camper should not be pulled with any modern FWD-based minivan.
We towed a 3000 lbs popup for 8 seasons with Chrysler minivans without issue. But without a HD towing package (without the aux trans cooler) these are usually limited to 2000 lbs, which rules out most popups.
Too bad.
thebrakeman is offline   Reply With Quote
Old 08-14-2014, 08:05 PM   #9
Or a tear drop.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
tow vehicle, trailer
