Old 06-01-2015, 08:33 PM   #1
Flybob's Avatar
Headsup if buying a new 3/4 TV
Some newer 3/4 ton vehicles have class IV hitches and the safety chain hooks are too small to fit in the designated holes in the receiver. Solution: I purchased two HD shackles that fit in receiver holes and attached safety chains to them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-01-2015, 09:39 PM   #2
Common issue that is solved by unlearning common instruction. Rather than hooking from bottom forward, hook from top back if that makes sense. You were taught to hook from the bottom with the shackle so the shank would travel further to come off. I have no idea what the new idea is to hooking from the top other than the way forces work or space was spec'ed. Class 5 and more are the same way.
CGO - A technical marketing data guru
Almost an owner of a 2014 Hemisphere 312QBUD
2011 Ford F-250 SD 6.7 Diesel
Texas outdoors by way of a PA farmboy.
ChiefGreedyOfficer is offline   Reply With Quote
