06-19-2018, 01:17 PM
Help......
Wife an I had a 2004 Nissan titan. When towing we used the tow mode and no overdrive.
Just bought an 2018 Nissan titan diesel. No where in the info books that came with the truck does it say anything other then use tow mode.
So...
Do I use tow mode and no overdrive like my old gas one, or tow mode AND overdrive?
Ps. 1st time diesel guy.
06-19-2018, 01:20 PM
Tow mode typically won't allow the engine to shift into OD. It'll also change the shift points so you get optimal torque and allow engine braking (if equipped).
I would use it when towing and that's it.
06-19-2018, 01:26 PM
Use tow mode and let it shift the transmission itself, don’t manually shift it or lock it out of OD unless you find it hunting for gears.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
06-19-2018, 01:47 PM
It’s near impossible to state what is typical regarding tow/haul mode. It depends on the make, model, year of the tow vehicle. My 2014 has 6 forward speeds. The top 2 are OD. Tow/haul mode locks out neither of them. BTW, it’s the transmission not the engine that shifts into overdrive(s). Do what’s suggested above —- use tow/haul if you are towing or hauling and let the transmission control module choose its own gears.
06-19-2018, 01:49 PM
Mr Dan.. we're saying the same thing.
06-19-2018, 06:24 PM
This does not answer the question. My 2005 Nissan Titan, that I previously that I owned, would shift into overdrive using tow mode. In the mountains it was always shifting and transmission temperature would rise if you did not prevent from going into overdrive.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
06-19-2018, 06:46 PM
X2 - this is your answer. Key to it is if you find it shifting out and back to OD a lot then drop it down out of OD manually until the situation causing it to hunt (i.e. Hills) passes. Simple as that.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
06-19-2018, 06:53 PM
I did answer your question and even addressed hunting for gears.
2013 Shamrock 21SS
06-19-2018, 06:55 PM
Gold Tee Box
Do you really need Tow mode at all? What are you towing?
You can search this forum for Tow mode threads and see those comments. I've never found the need to use it as my vehicles easily handle the load and shift nicely. Tow mode causes higher acceleration between gears and is unnecessary unless I was really at the limit of tow capacity.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
06-19-2018, 07:50 PM
I did a simple search and it sounds like the Nissan tow mode still allows shifting into OD.
Honestly, if it was me I'd see what works best for you. tranny temp is something you'll.want to watch nothing will kill a tranny faster than heat.
If you don't have a guage then I'd recommend a simple OBD port reader and the Torque app. That'll give you actual numbers to.work with.
06-19-2018, 07:58 PM
I can’t answer specifically to the diesel but with my 2017 xd gas if I don’t lock it into 6th gear the rpm’s run way to low for my liking and it really hunts for gears. When in rolling hills I will lock it into 5th. I have not noticed any difference in fuel mileage regardless of what gear I have locked out. You are correct that the manual doesn’t address this.
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
06-19-2018, 08:09 PM
I have a 2016 Titan XD diesel, use the tow mode. Shifts into OD, downshifts when braking and works splendidly with cruise control.
2015 Tracer 3140RSD Touring
2016 Nissan Titan XD Diesel
Blue Ox Swaypro BXW1500
06-20-2018, 10:38 AM
Yup, exactly what we do. On the Ram HD you have tow/haul and you can also lockout higher gears as needed. With our TT, I know it will likely downshift (and sometimes a bit harsh) while going up longer hills, so I'll lockout 6th ahead of time and keep it locked out in hilly areas. Puts it right in the powerband for the speed we travel at.
I think the 'no OD while towing' comes from a couple decades ago, doesn't necessarily apply anymore.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
