Old 03-16-2014, 08:13 PM   #1
Janet794's Avatar
We are to leave on a 5 week trip in the morning. We moved the travel trailer scerosis the road with no problem, well there is the problem of mice, and tonight we were hooking it back up in preparation to leave first thing in the AM and.......the electric jack will not work. We changed the fuse and it proceeded to blow 3 fuses with an active spark. Then the bolt on the manual crank part broke, and we cannot get the TT cranked up to connect to the truck.
HELP!!!!!!!!! I really hope someone is online currently with problem solving ideas. Thank-you
Janet794 is offline   Reply With Quote
Old 03-16-2014, 09:31 PM   #2
Janet794's Avatar
Problem solving
So, our problem solving has moved us to call around and find a new power jack and install it ourselves. Any suggestions on a replacement? We currently have a LCI.
Old 03-16-2014, 09:35 PM   #3
I think the Barker jacks get good reviews from folks on the forum.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 03-16-2014, 09:54 PM   #4
B and B's Avatar
I used a 1/2 inch drill on low speed to run as manual jack backup. I just cut the one jack arm off and chucked it in the drill. Worked great. You can use a 1/2 square drive impact wrench and socket as well.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 03-16-2014, 10:10 PM   #5
jtstromsburg's Avatar
Use a bottle or floor jack, carefully, to lift the trailer onto the truck hitch ball. Then, grab a new power jack when on the road and fix at setup. Should be easy. Good luck
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-16-2014, 10:21 PM   #6
^ X2. I would also figure out where the short is in the wiring. Clearly there is a short between the jack and the battery that is causing the spark and blown fuse.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
