Old 03-03-2011, 12:16 AM   #11
bsmall's Avatar
Originally Posted by HookMeUp View Post
Is your the sliding bar type? If so these are known for the symtoms you discribe. I don't know if there is an adjustment or not.
"Is this the sliding bar type". HookMeUp are you refering to the hitch slider or something else??
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is online now   Reply With Quote
Old 03-03-2011, 05:59 AM   #12
cardinal4fun's Avatar
As for greasing the king pin!! I have the 5th Airboune king pin with the curt 20k hitch. The curt would really grab the king pin and cause kinda what you are talking about. Both the 5th ab and curt people told me to put a very very small amount of grease on the king pin. This did help, it has since become one of my pre hook up items to cover. I also have the disk but thats for a different movement.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 03-03-2011, 06:05 AM   #13
Herk7769's Avatar
Originally Posted by bobsquarepants View Post
I'm by no means an experienced 5ver owner (only had one for a year now) but isn't some of this caused by weight distribution? I know when I first brought my trailer home (550 miles) empty, it felt really jerky and loose with alot of chucking...fast forward to vacation time and with the 5th loaded, it felt more solid. Hitch a is Reese 16k slider...double jaw / double pivot
Bob, I was thinking the very same thing. After the hitch assembly is inspected; my next stop would be the scales.
15-25% of the camper's weight must rest on the hitch. Overly light and overly heavy pin weights will cause all kinds of ride problems.
HAM CALLSIGN - KC3FFW
Old 03-03-2011, 06:42 AM   #14
Thanks for the advice folks. I think I'm going to have to get the trailer back out of storage this spring and do a bit more closer inspection on the king pin and hitch, and possibly take it in to the dealer. Hopefully its a minor adjustment as some have mentioned.
My hitch has the manual slider bars. I could see how any loose play might cause this jerking problem if the upper hitch assembly is not held securely when locked in the tow position. This will also be on my list of things to inspect.
As for the weight distribution...what I recall from last year is that I experienced this both loaded and unloaded. That's not to say my loaded weight is all right. I'll have to get to the scales this spring as well.
I did plan to start greasing the king pin a little this year. Each pivot you make with the trailer and TV puts a lot of wear and friction on the circumference of the pin and hitch jaw. Does anyone have any grease recommendations to use?
I will update everyone when I find out more details. Thanks!
E.S.P.
'07 Rockwood 8281SS 5th Wheel
'07 Silverado 2500HD LMM Duramax Diesel / Allison 1000 CC 2LT S/B
Reese 15K 5th Wheel Hitch w/ Kwik-Slide
E.S.P. is offline   Reply With Quote
