Old 03-06-2014, 06:22 PM   #21
Originally Posted by jevanb View Post
you and the OP pretty much have the same HP but he will be towing 4-5k lbs more. I had a 2004HD 4x4 CC with the 6.0 and it was a slug in any hill I also did not like 2nd gear and 5000 rpm to make the top, the flats were ok towing..
Pulled across the SC state scales on the way back from FL and grossed out at 15,100 ave 9.9 mpg and the last 100 miles were into a headwind. With the air bags at 60#, still lacked 1/2" of being on the overload springs.
Old 03-06-2014, 06:25 PM   #22
D-maxx dave's Avatar
Sorry!
If I high jacked, I'm sorry! But the 365SSAQB weights are almost equal with the 355RE. Thanks for the help! Think I've figured figured out we're ok!
Best of luck, Johnnie !!!
D-maxx dave is offline   Reply With Quote
Old 03-07-2014, 04:37 PM   #23
Crusadernoob's Avatar
I am not sure why so many people say what they can tow and do tow and never have any problems even tho they know it's over the GVW, the FIRST thing that will be overloaded will be the tires, all of the 2,500's, 250's will handle these fifth wheels with no problem, the question that very few people ask is "Is this too much for my tires?" Look at the max rated weight for one tire, times by 2, weigh the rear axle when the vehicle is full of fuel, people, hitch, and supplies, and this is what the pin weight SHOULDN'T go over, and if you would like a little cushion, give yourself a few hundred pounds lighter pin weight. This is how a truck and trailer combo should be configured.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is online now   Reply With Quote
Old 03-07-2014, 04:44 PM   #24
I have GY Wrangler LT LR E at 55psi rear & 45psi front.
Old 03-07-2014, 05:10 PM   #25
Thank you all I am still looking for a fifth wheel
rpbscm06 is offline   Reply With Quote
5th wheel, truck, wheel
