Old 08-25-2016, 07:19 PM   #71
fastalkintn's Avatar
Originally Posted by Oithumper View Post
That looks a lot better than the first picture. What did they end up doing to get it more in line? Hope your trip goes well.
With the initial setup they only put 3 washers in and the head was actually tilted up before loaded. They added 4 washers and now the head is tilted down before loading. The only downside is the bars are near impossible to put on the brackets
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
fastalkintn is online now   Reply With Quote
Old 08-25-2016, 07:33 PM   #72
Latch on to the ball then use the tongue jack to raise the truck some. This will help to secure the bars. Glad to see dealer helping you make it right. Good luck out there, be safe.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 7 nights
Miles traveled in 2017: 1,450
uhduh camping is offline   Reply With Quote
Old 08-25-2016, 07:35 PM   #73
Only problem is I run out of tongue jack before it's high enough. I've got to get a 6"x6" to use.
2017 Salem 27RKSS
Old 08-25-2016, 07:45 PM   #74
You have other options
https://www.fastwaytrailer.com/flip-jack-foot
Hensley Arrow
Old 08-25-2016, 07:52 PM   #75
I forgot to mention your tongue jack is most likely adjustable too. Pull the pin out down by the foot, the foot has adjustment holes.
Hensley Arrow
Old 08-25-2016, 07:54 PM   #76
Hugeez's Avatar
They make a cheater bar for that E2 WDH. After getting our adjusted properly, it is nearly impossible to get the bars up on the L brackets without the cheater. Part number 92-00-6000
2015 Puma 29RBKS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
Hugeez is offline   Reply With Quote
Old 08-25-2016, 07:56 PM   #77
Let's us know how it pulls now. Hopefully no more white knuckle.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 08-25-2016, 07:58 PM   #78
I actually pulled it about 15 miles today. It pulls much better, still has a little sway but coming from a pop up I think Im being over sensitive.
2017 Salem 27RKSS
Old 08-25-2016, 08:25 PM   #79
asquared's Avatar
x2 on using the tongue Jack to raise the truck rear. This takes the pressure of the truck making hitching easier. Use the cheater bar in addition to this to make it even easier.
We used to keep a 4x6 block of wood under ours. We actually cut a 4x6 into 12" long sections and used 2 under each stab Jack. We screwed little metal handles to them to make moving them about easier.
Is it true side to side sway? Sway is defined as side to side movement that increases in speed and size as it goes. This should not occur at all. A little tail wiggle is normal. This is where the rear of trailer wiggled side to side a little bit but not into other lanes and not such that it is true sway or affects handling. Or do you have porpoising which is where you have up and down bounce from front to rear like a wave? Or do you have tail wagging the dog where the traiker steers the truck? Each can be fixed but require different fixes.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 08-25-2016, 08:37 PM   #80
After the adjustment today I don't have any porpoising at all. I wouldn't classify it as true sway and it definitely isn't the tail wagging the dog. I am used to not even knowing my pop up was back there so any movement makes me a little nervous but I'm sure as I get more accustomed to it it will be fine.
2017 Salem 27RKSS
