Old 06-14-2016, 12:12 PM   #1
schrederman's Avatar
Help from Ram 2500 owners... please
I have a '14 Ram 2500 Crew Cab 4X4. I've looked several times for places to grease my front end and I can't find a grease zerk fitting anywhere. I've watched videos of a guy using a needle to grease a U-joint in the front drive shaft. Mine doesn't have the same drive shaft, apparently. I can find nowhere to pump grease into this truck's front end workings. Am I missing anything?
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-14-2016, 12:34 PM   #2
Head Rambler
Have you looked over at Turbo Diesel Register (TDR)? You'll probably get an answer faster over there.
Gotta go campin!
Old 06-14-2016, 12:36 PM   #3
Kenny kustom's Avatar
The only lube point is the driveshaft.
That's it, that's all.....
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-14-2016, 12:40 PM   #4
2016 Sabre 36QBOK
My driveshaft is different from the one in the videos and there's no hole and no rubber boot...
Old 06-14-2016, 01:12 PM   #5
Aca651's Avatar
Vehicles no longer come equipped with grease fittings. You can get a needle that will prince the boot and grease it that way. I don't like that plan. When parts get replaced, always ask for the premium part and it will come with a fitting.
Aca651 is offline   Reply With Quote
Old 06-14-2016, 01:28 PM   #6
Finster's Avatar
I don't have a 2500, I have a 1500 but mine was more or less the same. I went through my front end a few weeks back and replaced the ball joints, and sway bar bushings and links. Everything I put back in was Moog, which comes with grease zerks. The factory stuff didn't have them.
2007 Dodge Ram 1500
2017 Shamrock 233s
Waterloo, Iowa
Finster is offline   Reply With Quote
Old 06-14-2016, 01:31 PM   #7
rsdata's Avatar
ask the same question on the Dodge RAM forum here
DodgeForum.com
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 06-14-2016, 02:02 PM   #8
Jim34RL's Avatar
This has been mention on the TDR form with the lack of grease fittings on the 4X$ trucks. It seems that some trucks with 4X4 axles have the recess grease fitting in the CVJ and some do not. My 2008 does not have the fitting but my son's truck does. I do know what to look for since I have owned three Jeeps in the past with the CVJ for the front axle that had the recess grease fitting.
Manufactures have been doing away with bearings that need to be greased on a maintenance schedule and designing in lubed for life bearings. Why? Most drivers today do not want to take the time to maintain a vehicle unless the dealer does the maintenance on it. With the dealer not wanting to take the time for some small amount of work and charging the customer $110 an hour for that work.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 06-14-2016, 03:31 PM   #9
I recently purchased a used 2105 Ram 3500 4WD Longhorn with just 17,000kms (10,500miles). The previous owner had owned it new since November 2015 and had done no maintenance what-so-ever on it, even including rotating the tires! I have always done my own running maintenance so set about the task. Unlike my previous 2006 Ram 3500 2WD, it was quite a task getting the Lube Oil Filter out. I had the same problem as yourself when trying to locate the grease point on the front drive shaft's rear universal joint. I could find nothing! I watched the YouTube Videos and decided that it must exist, as there is even a note under the hood stating that it should be greased at every oil change. So, I got a very thin piece of fairly stiff wire about 4" long and went poking for it everywhere that had been shown on the videos. I FINALLY FOUND IT! I then marked it's location using metal marker so that it would be a bit easier next time. I had got a grease gun needle adapter already and promptly broke the thing trying to get it in the hole. Off to the store for another one. Worked this time as I was a lot more careful. Managed to pump the required grease until it oozed out but there was lots that oozed out also around the needle. It is there but very, very difficult to find! It is the only point on the truck that requires greasing. Hope this helps.
kcdelan is offline   Reply With Quote
Old 06-14-2016, 04:13 PM   #10
BBBlue's Avatar
I have a 2013 3500 Ram 4x4 and had difficulty finding the grease hole. It is not a zerk fitting and requires a needle like tube that is fitted on the end of a grease gun to get the grease into that area. Difficult but doable. Once you find it, mark it. I attached a pdf that describes that area. Google it and there are videos online that demo the greasing and how to find the grease hole. Good luck.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
