Old 03-28-2019, 11:43 AM   #1
Help Identifying equipment on a TOAD I am looking at
Can Anyone tell me what is on this car as a TOAD setup?
Possible the manufacture of the base plate and help identifying the other two devices?
I am considering this car as a toad and noticed these things - the dealer who has it didn't know it was set up as a TOAD and doesn't have a lot of info on it.
Thanks!
mparus1 is offline   Reply With Quote
Old 03-28-2019, 11:56 AM   #2
PPST Wannabe
kenandterry's Avatar
First off......your dealer knows nothing about vehicles set up to be towed with four wheels down. What kind of dealer is he?
Second.....it’s possible the mileage on your odometer does not include any mileage the vehicle was towed besides the mileage when it was driven.
The connector on the left is where you insert the pin for pulling, using a Blue Ox or similar design towing mechanism.
The next flat bar with the opening is for attaching your safety cables.
The silver connector with the chrome ring is to connect your breakaway activator to the motorhome. It pulls the ring OUT....and this activates Emergency braking in case the towed vehicle disconnects from the motorhome.
Hope that helps.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 03-28-2019, 11:59 AM   #3
PPST Wannabe
Different roads....different rules for set up
By the way.....the title should read
Different toads....not roads
What year, make and model is this toad?
They’re all different and then sometimes there’s speed limits also.
The tow bar needs to tow level to these mounting points.
Lots to review if you just wanna know.
Ken and Terry
Old 03-28-2019, 12:25 PM   #4
It is a 2015 Subaru Forester - found it on line at a Ford dealer in PA.
I checked the 2015 version of the MotorHome towing guide to be sure it was flat towable
Old 03-28-2019, 01:07 PM   #5
dcheatwood's Avatar
Don't tell the dealers it has several thousand dollars of towing equipment. He'll up the price.
2018 Forester 3011 DS
Old 03-28-2019, 01:25 PM   #6
PPST Wannabe
There are others on here with Subaru toads so I know some of them work well for that purpose. However, unless someone tells me otherwise, the odometer does not record the mileage of when it was towed.....just sayiní.
The installed framework for towing the Subaru wouldnít be a thousand dollars, and each design is specific to a make and model so it canít be used on a vehicle other than what itís made for.
Ken and Terry
Old 03-29-2019, 12:24 PM   #7
BobHanke's Avatar
Should see another item on the front of that car. The electrical connection for running, brake and turn lights. Might also have an always live 12V connection for battery charging if car will draw power while being towed.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
Old 03-29-2019, 01:23 PM   #8
This appears to have a Blue Ox base plate. There are two twist-lock pins that fit in the far outside fittings. The pins are part of the base plate kit. If there is a storage compartment under the cargo area, they may be stored there. If not, if you do purchase the toad, ask the dealer if they have the parts once the deal is done. They may have removed them when the vehicle was detailed. If not, get the previous owner information off the title. They may have them. The base plate and associated parts are separate from the tow bar. The pins would have little to no value if sold with the tow bar or to the previous owner. They may also be available thru Blue Ox. See the pictures of our Jeep toad. They are identical to your photo.
ID:	200134   Click image for larger version
ID:	200135   Click image for larger version
PenJoe is offline   Reply With Quote
Old 03-29-2019, 01:24 PM   #9
Suggest you go to Remco Towing website, it's full of information about toad requirements. This Subaru must be a standard shift if set up to tow. You didn't mention model, engine size or type of transmission. Store : Remco
Oltimer13 is offline   Reply With Quote
Old 03-29-2019, 01:27 PM   #10
Papaduck's Avatar
Appears to be a BlueOx baseplate configuration. You will need a set of adapter pins ( https://www.etrailer.com/Accessories...BX62-3468.html) to connect the tow bar to the baseplate. I have an extra set of pins for sale. Send me a private message if interested.
Chuck & Donna
U.S. Army - Retired
2016 FR3 30DS w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 28
Papaduck is offline   Reply With Quote
toad
