Old 03-29-2015, 07:20 PM   #1
Help on weight distribution hitch
my new cherokee 274dbh weighs 6200 with tongue weight of 902 pounds. Is a hitch rated for 1000 pound tongue weight and 10000 pound trailer weight ok for this or should I go bigger when loaded the trailer will be around 7200 I am assuming the tongue weight increases when trailer is loaded but not sure by how much. Thanks for any help you can lend me on this subject
RC08 is offline   Reply With Quote
Old 03-29-2015, 07:34 PM   #2
bikendan's Avatar
if the "dry" tongue weight is 902lbs., you'll need a bigger hitch.
that amount doesn't include the weights of the battery, propane, water and cargo.
just the propane and battery will put you around 75lbs. more and you can be assured that with cargo and water, you'll easily be over the 1000lbs. hitch's capacity.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-29-2015, 07:42 PM   #3
ok thanks I was wondering about that so I will go up to 1200 tongue and 12000 trailer then. Wasn't sure if 12000 pound bars mattered if trailer only weighed around 7300 loaded. is there such a thing as too much bar for the trailer. thanks for your help again. if you haven't noticed I'm new too this
Old 03-29-2015, 07:53 PM   #4
asquared's Avatar
Go with the 1200/12000 lb hitch.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-30-2015, 12:05 PM   #5
D_B Travelers's Avatar
Hitch weight
Agreed! 1200# hitch
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 Ė 1996)
D_B Travelers is offline   Reply With Quote
Old 03-30-2015, 12:10 PM   #6
Stormrider151's Avatar
Yes, you can have too much spring bar. If for instance you were to go with a 1400 lb. spring bar it would be too stiff for the bars to function as deigned. For one thing the ride would be awful. I would think given the weights you have described the 1200 lb. bars would be what you need.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-30-2015, 02:20 PM   #7
thebrakeman's Avatar
Being right at the limit of a WDH system won't break anything, nut it won't be stiff enough. I believe this is where a lot of people get that porpoising effect, where the bars are just constantly flexing and springing.
1400 lbs bars (as was said) might end up having not enough flex, and giving you a harsh ride. Imagine your car with springs that were too stiff. Suspension would not absorb bumps.
1200 sounds like your sweet spot.
thebrakeman is offline   Reply With Quote
Old 03-30-2015, 03:08 PM   #8
Thanks to everyone for the information I order the 1200/12000 pound Equal-i-zer this morning.
Old 03-30-2015, 06:23 PM   #9
Hitch
Good Choice! Trailer may be a little noisy when turning due to metal to metal friction of the side bars, but that's not a huge problem.
gfarmcafe is offline   Reply With Quote
Old 04-01-2015, 11:15 AM   #10
I run with the Sway Bracket Jackets, and they have helped greatly.
hitch, weight
