This is a 2012 Sunseeker 3120ds towing a 2011 Jeep Wrangler unlimited.
I would like to get the pro’s and con’s from the group to help me make a choice on what brake controller to go with. I have it narrowed down to 3 units.
US Gear Unified Tow Brake UTB cost $1,363
Pro’s
1. different features
2. stays in the Toad
3. control from the motor home
4. true progressive/proportional
5. uses the Toad’s power brakes
Con’s
1. Hard to install?
2. No dealer help if I have install issues
Roadmaster Invisi Brake $900
Pro’s
1. Stays in Toad
2. Bypasses the 12 volt and charges the Toad batt
3. Progressive braking?
Con’s
1. No adjustment from the motor home
2. activates when the brake lights on the motor home comes on.
Brake buddy Vantage Select $1,500
Pro’s
1. easy to install
2. setting can be changed from the motor home
3. proportional or full braking
4. installed and backed by a dealer I trust
Con’s
1. you have a braking system on the floor of the Toad
2. you have to hook it up and break it down each time
