Old 08-23-2012, 08:28 AM   #11
MtnGuy's Avatar
Originally Posted by punkaccountant View Post
There is a pretty lengthy write-up on the new design of the Blue Ox hitch on RV.net. I would check it out as it may answer your question. Look in the Towing sub-forum for the thread titled "Getting Rid of my Dual Cam System." the relevant info is a couple pages into that thread.
GASP........I can't believe you made reference to "that other forum" !!!
Here is the link: RV.Net Open Roads Forum: Towing: Getting Rid of my Dual Cam system
Old 08-23-2012, 08:32 AM   #12
Experienced Newbie
From what I just read regarding the "new" Blue Ox hitch, their research found that the hitch head angle had less to do with the sway prevention than the tension on the bars. This was with the newer rotating latches they have. The hitch head angle is now a fixed angle and the spring bar heads are assembled at an angle similar to the caster of your front wheels allowing the bars to "self-center" and reduce dog-tracking.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 08-23-2012, 11:00 AM   #13
I had my appointment today. I was all set to have them replace the Blue Ox with a Reese Dual Cam. The dealership that installed the hitch said the ball was set to low. Their mistake - they apologized but it sure doesn't instill confidence in them. They raised the hitch ball height. I took it for a test drive with them and was able to drive without any sway. I had trucks passing me and didn't notice any sway. I was able to make a quick lane change at 75 mph with little to no sway. The only problem now is that I get quite a bit if bucking up and down. I leave for s trip tomorrow that requires a long drive do we will see. I am going to call Blue Ox today. Dealer said the bucking was due to height the ball needed to at for sway control. I am the sway is eliminated but the bucking may be an issue. Jury still out on the hitch but I will say it is the easiest hitch to hook up no matter how the TV and TT are situated. No noise, difficulty backing up, or making sharp turns with the system. Thanks for the posts especially the one leading me to RV.net!!!
bucsplace is offline   Reply With Quote
Old 09-13-2012, 09:53 PM   #14
Blue Ox Sway Pro
Still working on setting my blue ox sway pro hitch up. I fianlly have it so there is little to no sway which is nice. Still have buckung up and down but the blue ox rep just set me new bars 750 lbs. that will hopefully address that issue. Despite my initial concerns this is the easist hitch to hook up, no issues backing up and can make sharp turns forward and backward. I will say that blue ox customer service has been outstanding. The blue ox rep has been great. Can't wait to try the new bars and hopefully all will go well!!! It has been refreashing to see a company go out of their way to make sure everything is just right!!!!!
Old 09-14-2012, 07:08 PM   #15
Wanna Be Camper
SaskCampers's Avatar
We drove almost 4000 miles this summer with our Blue Ox and have a total of over 12,000 miles with it and I would not trade it for anything save for maybe a Pro Pride or Hensley.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-25-2012, 04:05 PM   #16
What is your TT and TV? What weight bars are you using?
Old 09-25-2012, 07:03 PM   #17
Enjoying Member
ScottnKimmer's Avatar
Have also have one with many thousands of miles. Trips vary from very short to many hours and miles. We back in without disconnecting and we turn as tight as possible without issue. We used to have a minor amount of bounce but that was due to the trucks suspension not being as strong as was needed and it only happened on serious dips in the road. We only ever felt uncomfortable behind tanker trucks and their cylinder shape. No other wind or road condition has caused us to be fearful. It is the tilt head design and it sounds like that is the one that works.
It sounds like they are working with you to correct your issues and get you towing solid as a rock.
Scott n Kimmer
Nights Camped: 2013-15 2012-28 2011-16 2010-10 2009-30
2007 Dodge Ram 1500 Quad Cab 2WD w/trailer pkg 345HP 5.7 Hemi/5spd Auto/3.92 Rear
2008 Wildwood 23FLSRV - Prodigy Brake Controller - BlueOx WD Hitch
2011 Harley Electra-Glide Ultra Limited (His Bike) - 2005 V-Star 650 Classic (Her Bike)
ScottnKimmer is offline   Reply With Quote
Old 09-26-2012, 07:59 AM   #18
Wanna Be Camper
At the time we had our 2008 Ram 2500 4x4 Megacab and our trailer is a 34 1/2' V-Lite with abt 800lbs tongue weight. I am running the 1000lb bars. Our hitch has the old style very heavy bars. WHen we first got it we had 1500lb bars and had some bounce issue but the dealer traded us straight across for the 1000lb ones, also had to weld a small extension the the bottom of the shank to drop the head to the lowest holes possible as the Dodge sat very high at the receiver. All has been good since.
John & Deb
blue ox
