Old 06-28-2016, 04:48 PM   #1
Help with calculations
I've tried to run the calculations but I keep getting confused by all the numbers. Our truck is a 2004 Ford F-250 142" XL 4wd. It's a 6.0L V8. When I do a VIN lookup it shows a max trailer weight for a fifth wheel at 13300 max. The tongue weight max is 1330.
We are looking at a Salem Hemisphere 368RLBHK which shows a UVW of 10924 and hitch weight of 2080.
Can our truck pull this camper?
salumbaugh is offline   Reply With Quote
Old 06-28-2016, 04:53 PM   #2
TURBS's Avatar
No
Sent from my SCH-R530U using Tapatalk
Old 06-28-2016, 04:57 PM   #3
BandJCarm's Avatar
No.
Not enough payload. The 13,300 number is meaningless until you have satisfied the payload. If the pin weight is 2080, plus you and other people and fuel and cargo.......is about 2,400? 2,800? 3,000? I dunno.......I will strongly guess that is way above your carrying capacity. Until that number is satisfied, how much it'll pull is immaterial.
My opinion.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-28-2016, 05:04 PM   #4
Oakman's Avatar
I find it hard to believe your 3/4 ton Ford has a payload rating of 1330. Are you sure that's not the conventional tongue weight and not the payload rating?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-28-2016, 05:24 PM   #5
This is where I get confused is by all the numbers.....
GCWR 20000
GVWR 8800
I'm not quite sure how to calculate the GVW.
Old 06-28-2016, 07:29 PM   #6
I found a payload rating of 2720 for our truck..... so how does that calculate out now? Sorry..... new to this and just trying to understand how all the numbers work into the equations.
Old 06-28-2016, 09:14 PM   #7
bikendan's Avatar
Where did you get this number?
If from the yellow drivers door sticker, then it should be accurate.
If not, then it may not be.
Equalizer WDH
