Old 07-04-2014, 03:05 PM   #21
RSchleder's Avatar
Not at all, we live in "Hawkeye land" too, and have been putting trailers behind our truck or cars behind a motorhome since 1992. I guess thats why they"re called TRAVEL TRAILERS! Good luck on getting the towing issue under control. Lot's of smart folks here to give you great info and assistance!
RSchleder is offline   Reply With Quote
Old 07-04-2014, 03:08 PM   #22
oh great to hear that! And yes this group is AWESOME! Will let you know what we figure out
tcsorenson is offline   Reply With Quote
Old 07-04-2014, 03:12 PM   #23
I agree with oc. You need to lower the front of the trailer.
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 07-04-2014, 07:01 PM   #24
we do carry firewood in the back of the truck along with kids bikes should we not be doing that? And once we get the hitch lowered and fix this sway problem would it be a bad decision to put a bike rack on back of trailer? any other idea's for carrying bikes?
Old 07-04-2014, 07:04 PM   #25
jonnys_walkers's Avatar
I am amazed there is no sway control arms attached.
It has been recommended to me that a trailer over 30 feet has two sway controls attached.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 07-04-2014, 07:05 PM   #26
Platokidd's Avatar
That hitch head don't look like no equalizer I've seen before. The bars and L brackets look like an equalizer. .
Mixed system??? Mine is a 4 point equalizer no sway hitch. Handles my 8500lbs 38 foot trailer no problem
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-04-2014, 07:11 PM   #27
HONDAMAN174's Avatar
I see where it says E2 on your WDH but I don't see any sway control arms. My Anderson probably would not be a good choice for your weight and length so maybe others will chime in on what works for them- maybe a four point?
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 07-04-2014, 08:02 PM   #28
Phat Phrog Stunt Crew
elind's Avatar
I'll agree with OC on readjusting. The front wheels need weight pushing down on them by lifting up on the hitch bars. You need the truck fairly level and then adjust the height of trailer to have it level also.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-04-2014, 08:28 PM   #29
Citrus County, Fl.
GL1800Rider's Avatar
See if you can raise the L brackets up one notch. Installation manual days țo start with two holes exposed on top and two on the bottom. Also make sure to tighten the angle bolt on the bottom of the hitch head 1/2 turn age it contacts the head but do this with the trailer hitched.
We just got ours and I had to re tighten the bolt when we got home from the dealer. I forgot to do it before we left and it was porposing pretty bad
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-04-2014, 08:51 PM   #30
That is a fastway E2 hitch (same company as equalizer). This hitch only has two point for sway control, not 4 like the equalizer. This trailer may be to big for the E2. I would start with OC's comment about getting your setup more level and see if it helps (hopefully it will) but you may need more sway control then the E2 can give you. The E2 works great on my trailer but it is only 3500 lbs and 20 feet.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
sway
