Old 07-11-2014, 11:40 AM   #61
ok just checked and we had front shocks put on not back so will get those back ones changed this week! they are also saying an overload kit would help? what is that???
tcsorenson is offline   Reply With Quote
Old 07-11-2014, 11:52 AM   #62
Looks like we just had front shocks put on so its going in Tuesday morning for back shocks let's hope this takes care of the problem!
Old 07-12-2014, 01:36 PM   #63
updhaul's Avatar
Let us know how new shocks go. FastwayTrailer.com a division of Progress MFG for decent adjustment instructions for an E2 hitch. Sometimes photos are deceptive, but it still looks like the verticle link bars and attached L bar are not "square" with frame. Fairly easy adjustment if they are not.
updhaul is offline   Reply With Quote
Old 07-13-2014, 07:55 AM   #64
Platokidd's Avatar
My L brackets are not perfectly square to the frame. I set mine up so the spring bar and L sit flush to each other for 100% contact
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-25-2014, 08:38 PM   #65
shocks on the truck were REALLY bad replaced those and that took alot of the bounce away, still is a bit bouncy but maybe that's normal
Old 07-26-2014, 09:48 PM   #66
Big earl's Avatar
Only one way to go. Pro Pride wdh. Expensive but worth every dime. Look it up on internet.
Big earl is offline   Reply With Quote
Old 08-17-2014, 08:11 PM   #67
@ Big Earl
Saw your propride post. I am looking at the Hensley and would like some more info
jrhino is offline   Reply With Quote
Old 08-17-2014, 08:55 PM   #68
Big earl's Avatar
Have you looked at pro prides website? I searched for a few months before making my decision. After reading the reviews and watching the videos I went with pro pride. It does everything it says
Old 08-17-2014, 09:24 PM   #69
Wolfpacduramaxman
I went with the Equal-i-zer Weight Distribution Hitch with 4-Point Sway and added rear air bags w/on board compressor. I can adjust the air pressure per the load weight I'm towing. Works like a charm.
Wolfpac Duramax
googmiester is offline   Reply With Quote
Old 08-18-2014, 08:34 AM   #70
sway
Received several msg from Hensley and seen a pro pride person posting on here. They are similar,I understand, are there any dif fbesides price? The H is intro a new(cheaper) arrow, and a lower price for the old style.
Seen post that PP is different for each TV. Do they both eliminate sway?
Have a 2014 28'(3 slide) rear kitchen Solaire 247(5900# dry). TV 2014 tundra 5.7 crew max/ 5.5'bed.A new reese w/sway-800# rated. It pulls, stops fine until certain trucks(cant predict which) or a sudden gust cross-wind causes loss of control up to a couple of seconds=that's 2(two) too many for this cowboy! Pulls/controls easily @ 60+ mph until either incident occurs-both at the same time results in the above mentioned situations.
sway
