Old 06-01-2012, 11:19 AM   #1
Help with tekonsha P3
Good afternoon,
After reading many great reviews of the prodigy p3 I bought one from adventurer rv. The brake controller was supposed to come with a small metal bracket to mount under the dash but it was not in the box. I requested they send me this missing piece however Im going camping June 8th and want the brakes to be working.
Can anyone suggest how to mount this with only the large metal bracket?
I hope this is not a stupid question but Im new to towing a camper and just picked up my camper a couple months ago. I wanted to mount it under the dash.
Thanks in advance!
xavier
2012 Forest River 206ltd
xavier is offline   Reply With Quote
Old 06-01-2012, 11:54 AM   #2
Are you talking about the "Under Dash Pocket Mount"? The one where it is just a plastic bracket that you can unclip the unit from? Are you going to be switching the P3 from TV to TV or do you want to remove it for some other reason?
The metal bracket is what most use. You can use the screws to mount it to the dash or you can even use industrial Velcro. If you use Velcro make sure to clean the dash plastic with some rubbing alcohol first. You have a lot of leeway on the angle from front to back on the P3, just make sure it is lined up in the line of travel.
Keep in mind that the small metal bracket and the plastic holder will stick out farther from the dash vs. the large metal bracket. My knees would probably hit it if I tried to use that mount.
Mine is flush-mounted in a pocket on the dashboard. I just used Velcro as the fit was pretty tight in the first place.
'15 XLR 27HFS
'15 Nissan NVP 3500 SL
Campers - Me, DW, 3 - DS (7, 5, 3), 2 large dogs
CHD Dad is offline   Reply With Quote
Old 06-01-2012, 12:26 PM   #3
Triguy's Avatar
I also recommend the permanent mount. I am using the plastic clip-on now with my P3 because I had two tow vehicles when I installed but now only have one and find that it sits too low. I'm 6'3" and my knees hit it occasionally.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-01-2012, 02:40 PM   #4
Awesome. Thank you both for the help!!!!! Tekonsha should be ashamed of their instructions. I read the manual front to back and watched their video that came with the controller. I even called their service line and they couldnt answer my questions. I guess they service many different brands and types of products. At least the quality of the unit itself seems good. I am only towing my pup so I'm going to take your advice and use the permanent bracket going forward. I thought the flush mount by its name was the better/preffered one to use.
Its installed. Going to take the pup for a test drive soon to make sure it works.
Thanks again!
xavier
Old 06-01-2012, 02:44 PM   #5
i meant to write under dash pocket mount, not flush mount.
xavier
Old 06-01-2012, 03:14 PM   #6
Triguy's Avatar
Let us know how it works for you.
Scott
2012 Shamrock 233S
Old 06-01-2012, 06:33 PM   #7
Works great!
Test drive went well. Was able to get used to hooking up the camper some more before my trip also.
Took this picture for the tow vehicles thread.
xavier
Old 06-01-2012, 10:43 PM   #8
skullskidr's Avatar
If you have a useless ash tray...
2012 Ford F350 Super Duty 4x4
ProPride 3P
2013 Windjammer 3006WK
1973 Camaro RS, LS6/475hp, 6spd
skullskidr is offline   Reply With Quote
Old 06-02-2012, 11:59 AM   #9
What is that gauge mounted where the coin holder / 4x4 selector is usually located?
I have my P3 mounted in the center pocket below the radio. I had looked where you have yours as well.
'15 XLR 27HFS
Old 06-03-2012, 01:53 PM   #10
Txcamper's Avatar
I put mine there as well. Works great!
Bo & Melanie Black from Canadian, TX
2011 Surveyor SPT295 "Our 1st RV"
2007 Toyota Tundra 5.7L 4x4 Double Cab
Txcamper is offline   Reply With Quote
Old 06-03-2012, 01:56 PM   #11
skullskidr's Avatar
That is the gauge for my air bags.
ProPride 3P
