Old 05-29-2012, 10:47 PM   #1
hockey11's Avatar
Help with tow recomendations
We just got our 21ft TT the max wgt is 7100#. We tow with an E150 Ford Conversion Van. The max tow on the vehicle is 7000#. We have not towed our TT to max wgt, however, our Van is having a hard time. We have been out on 2 trips & it will tow at 65mph or less. MN hills are a struggle, we are thinking we need to upgrade. We are not fulltimers, so we need an everyday vehicle. No more children, 2 german shepherds. We are thinking the f150 ecoboost. Any info, experience, or suggestions would be helpful!!!
Sharon & Jim, Dutchess
Windjammer 2102w
Ford f150 4x4 EB 2014
2012 30, 2013 25, 2014 29, 2015 37
hockey11 is offline   Reply With Quote
Old 05-29-2012, 10:54 PM   #2
While there are lots of glowing reports of how well the eco tows, IMHO there is no substitute for cubic inches. Small block motors simply cannot produce the torque required for proper towing. And the only advantage you will see is a bit better fuel economy when not towing, but no better when towing. Since it appears you are locked into Ford IMHO you would be better off looking at the V8 version.
Old 05-29-2012, 11:23 PM   #3
Plenty of reports on here about ecoboost. Do a search on here, and see what others have said. Good luck with your decision.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-29-2012, 11:40 PM   #4
bikendan's Avatar
by the way, your trailer is 24' 6" long, not 21'. the 21 in the 2102 has nothing to do with the trailer's actual length.
you need to post the van's engine size, rear end ratio and if it has the factory tow package, to give us an idea of the van's capability.
because it's a conversion van, the extra weight of the conversion lowers the van's towing capacity.
that said, the Ecoboost had many happy owners and is a towing beast.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-29-2012, 11:41 PM   #5
hockey11's Avatar
Just wanted to add that we are not set on the ecoboost, we are open to all trucks as a possibility. We just want something that will tow our trailer with ease in both flat & mountainous terrain. Also off road would be good!!! We want to do some boondocking. thanks
Windjammer 2102w
Old 05-30-2012, 12:03 AM   #6
Rsgtivr6's Avatar
I pulled our TT with little trouble behind the Ram (roughly 5800lbs for now) and got 9 avg going through towns, short hwy stretches and some small hills. Never felt like it was out of power when I needed it.
The new ones have a 10k max tow on a CCSB 1500 Express (cheaper decently equiped model) with 3.92 gears. Also, with the hemi you get 20mpg hwy due to the multi-displacement design. (seen most people state between 17-19 avg's at hwy speed limits). That is on par with Ecoboost real world numbers. Also sporting 390bhp and 407 lb/ft torque naturally aspirated is not too shabby. For around town, it has the coil rear suspension instead of the springs for a smoother ride. And then there is the Hemi exhaust note...
I am a Ram fan, so just showing the other side of the fence. Not trying to say one is better than the other (however biased I may be--blue oval hater from the crib, lol), just dropping some info for you since you asked for it. In your weight range, the only real factor that will be an issue is looks and percieved quality from a new truck. In either case, do your research and make sure you find your best fit! Check F150, Ram, GMC, Tundra or whatever vehicle you are looking at, forums for issues and concerns, or just reasons why they love/hate their trucks. That's how I came to my decision that FR was the right product for me.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 05-30-2012, 12:03 AM   #7
Ford F250 with the new (sort of), 6.2 Liter V8, gas, super cab, 4x4, with tow package. Has a little more grunt than the ecoboost, and the suspension for towing. Mileage when empty should be no worse than the van you have now.
No I don't have one, but I want one. I'm towing 7000 pounds with a F150, and 5.4L, in the mountains of North Carolina. It works ok, but I want a new truck.
LadyWindrider
Old 05-30-2012, 07:11 AM   #8
Barnman1's Avatar
I have an 11 ecoboost. I love it. It is my daily driver, 80 miles per day. Just look at the specs and get what you are comfortable with. Mine came with P tires standard, after pulling with them a few times I went and got LT tires and notice a big difference pulling with them.
Barnman1 is offline   Reply With Quote
Old 05-30-2012, 09:26 AM   #9
Actually, the V6 ecoboost is the F150's top towing engine with plenty of lower RPM torque and more than enough HP.
I have the 5.0 V8 in my 2011 F150 and it tows my 6200# trailer with no problems but the ecoboost has a little extra oomph compared to mine..
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 05-30-2012, 10:06 AM   #10
hockey11, I'd like to refer you to a post by Acadianbob regarding his ecoboost. It is under towing hitches and toads and the the topic is F150 review, 3300 mile trip.
I too recently bought an f150 ecoboost. I have not towed with it yet but it does have a diesel like torque. What I mean by that is the power comes on a low revs. This is what I was looking for since, I did not want to have something running down the highway at 3500-4500 rpm just to keep speed. My 97 f150 with 5.4 was doing just that. I tried to keep it in 3rd gear around 2400rpm as much as possible, but I was basically only good on the flat ground(my trailer is a North trail 31bdss with a gvw of 8600- not sure on actual weight yet). The alternative I looked at is a gm max tow with a 6.2. That one also had great power, seemed a little better on fuel than the ecoboost. But the power of the ecoboost still comes on at lower revs and the screw cab was a little bigger. I have five kids, so I need all the space I can get.
saskrick is offline   Reply With Quote
