Old 02-11-2016, 06:22 PM   #51
AquaMan's Avatar
Originally Posted by DSQR View Post
And going to the 2016 Ford Towing guide, looking for a 5th wheel capacity equal to or greater than 16,800#, you see that only an F350 diesel dually will do it. No Gas, No single rear wheel, nothing less than an F350.
That's because it's a Ford.
Pass the popcorn....
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-11-2016, 06:54 PM   #52
Very true! if it were a Chevy or a RAM you'd 3 of them.
End of flaming.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 02-11-2016, 08:28 PM   #53
Lvn2tvl's Avatar
I went down the same path your going down now so trust me that these responses are dead on. Just remember the certified weight labels for each vehicle are unique and are the ones you must use to calculate the adjusted payload capacity of any TV you are interested in purchasing.
I posted this earlier after discovering I didn't purchase what I thought I was purchasing and thought it might be helpful to you.
"Duramax 6.6L 4X4 actual axle weights look wrong"
Enjoy your TV search.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 02-12-2016, 02:01 PM   #54
Thanks for looking at the guide. Since the OP was asking about a FW that maxed out at 16,800lbs, he could pull it with a 2016 SRW F350 as long as he keeps it at 16,799lbs or less. Perhaps leaving a pound of coffee at home would make him legal.
phillyg is offline   Reply With Quote
Old 02-12-2016, 07:08 PM   #55
I would leave all food at home before I left coffee. As I learn about this stuff the wife and I have been looking at smaller and more importantly lighter 5th wheels. My main problem with DRW is it wouldnt fit in our garage, its tight enough with a SRW. And the rare occasion when the DW has to drive the truck to work, she has to park in a parking garage and she doesn't want to try to park in those tiny spaces.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 02-12-2016, 08:49 PM   #56
drittal's Avatar
DRW isn't wider than the mirrors, unless you have to fold them in to get in your garage a DRW will fit.
drittal is online now   Reply With Quote
Old 02-13-2016, 04:32 PM   #57
I do have to have them folded and retracted to fit into our garage. Not fun but it is what it is.
Old 02-13-2016, 08:44 PM   #58
Iwannacamp's Avatar
Ok. That solves it. New garage, new 5er and new truck.
Problem solved.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 02-13-2016, 08:54 PM   #59
Problem solved.
I like the way you think. Sadly the DW and bank account doesn't. Lol
Old 02-14-2016, 10:07 AM   #60
CDR USN Ret
He'd have to leave more than a pound of coffee.
Max single-wheel 5er weight from tables is 16,600# with a 2wd regular cab F250. That goes down to 16,500# with the F350 regular cab.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
5th wheel, wheel
