Old 08-28-2016, 02:03 PM   #1
Helper springs vs. Air bags
Hi everyone.
I'm pulling a 2017 Grey Wolf 26DBH with my 2005 Ram 1500 Big Horn. No problems at all pulling the trailer (usually loaded to around 6500#) but when loaded up I sit about a 1/2" lower in the back of the truck than in the front. I'm trying to decide between purchasing some Hellwig LP35 helper springs or going with an Airlift Load Lifter 5000 air bag kit. A new 3/4 ton truck is not in my immediate plans (dang house addition!), so that's out of the question. Any preferences between the two kits?
Thanks!!
2017 Forest River Gray Wolf 26DBH
2005 Ram 1500 Big Horn 5.7L HEMI
Moellerdan is offline   Reply With Quote
Old 08-28-2016, 04:47 PM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
The Hellwig kit is an actual spring that is going to affect the ride unloaded as well as loaded. Airlift air bag kit you can simply deflate to 5lbs. When not towing and still have the cushy ride.
With that said I have the Airlift kit and love it. I went over and beyond by installing an on board compressor with electronic valves with a momentary rocker switch so I can adjust the ride from the cab. Airlift does offer a kit that does the same, but I wanted a higher capacity air compressor.
If you look around I think you'll see most go airbags.
05CrewDually is offline   Reply With Quote
Old 08-29-2016, 08:51 PM   #3
Tom
Seachaser186's Avatar
The Hellwig progressives or the Supersprings do not affect the ride unloaded. In reality I can only speak for the Supersprings because that what I have on my '16 F150.
Seachaser186 is offline   Reply With Quote
Old 08-29-2016, 09:00 PM   #4
Tom
I was going to get airbags until a seasoned friend told me about the Supersprings. They really help with the sag and stiffens up the rear end adding extra control when towing.
Old 08-29-2016, 09:03 PM   #5
You don't need bags or springs.. You need a good weight distribution hitch. The bags are not going to transfer weight to the front axle, they are just going to lift the rear of the truck.
1/2 inch is not much. A good wdh will more than fix your problem..
2016 Siverback 33IK
Old 08-29-2016, 09:11 PM   #6
Tom
I use the Supersprings in conjunction with the WDH. It helps with the sag when I hook up the camper prior to adjusting the WDH. The Supersprings stay in play when you are towing reducing sway or roll on the vehicle rear end.
Old 08-29-2016, 09:24 PM   #7
The whole purpose of a WDH is to remove the sag and redistribute the weight onto the front axle. I guess each to his own but once you add the super springs they are there if you are towing or not. Don't know how that effects the drive for a daily driver...
Usually use bags or springs when towing a 5th wheel as weight is right over the axle...
2016 Siverback 33IK
Old 08-30-2016, 01:34 PM   #8
I have bags. Easier install and they are adjustable. However, since install, we have not needed to raise them. Maintained five to ten psi and all OK. But if I gave a heavier load up they go and down when finished.
2017 Mini Lite 2506S front kitchen
2018 GMC Sierra 1500
labcamper is offline   Reply With Quote
Old 08-30-2016, 02:11 PM   #9
ben31's Avatar
Supersprings and adjusting the WDH.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 08-30-2016, 02:24 PM   #10
thebrakeman's Avatar
Originally Posted by Moellerdan View Post
Hi everyone.
Thanks!!
What WDH kit are you using?
...you are using a WDH, right?
thebrakeman is offline   Reply With Quote
air bags
