Old 05-31-2016, 12:13 AM   #11
If you're not raising the rear of the truck/SUV up before you're snapping the chains then you're not getting much tension on them. On our previous TT I had to raise the rear of the truck when hitched about 5-6" to get the links I needed. That and the fact that I had 6 washers in the WD head made the bar ends really tilt down.
You need to study the proper way to hitch up a TT to understand how the WD works.
You may need to add washers as well as links.
Also are you using a WD with built in sway control? You should, it'll make towing much nicer.
goduc is offline   Reply With Quote
Old 06-04-2016, 07:46 AM   #12
If you changed trailers or tow vehicle, I would suggest getting WDH set up accordingly to your current configuration.
2017 F350 SRW Gasser
2016 Keystone Passport 3350BH
MarcS is offline   Reply With Quote
