Old 10-04-2018, 01:55 PM   #1
Hit the Cat Scale
Here are my numbers from todays weigh, 17 Expedition, 19 Mini Lite 2508, Hensley Hitch:
Truck Specs, 3550 Steer, 4300 Drive, 7500 GVW, 15200 GCW
Trailer Specs, 5980 GVW, 4464 Dry, 660 Hitch dry
1) Truck Only, 3120 Steer, 3180 Drive, 6300 Gross
2) Truck, Trailer, bars loose, 2580 Steer, 4620 Drive, 7200 GVW, 4000 Trailer, 11200 Combined. Wow did the front get light, rear axle is 320 over.
3) Hensley 1000lb bars jacked all the way, 3080 Steer, 3940 Drive, 7020 GVW, 4180 Trailer, 11200 Combo. Tongue weight calculates to 900 pounds (this included the entire Hensley set up, 2 full 30lb propane, battery and stuff in front storage, Hensley stinger was weighted with the truck, so my best guess is true tongue weight is 700).
** Fender measurements went like this,
Truck 35-1/2 F 34-5/8 R
Combo no bars, 36-1/2, 32-3/8
Combo with bars, 35-1/2, 33-1/2
Impressions: Under all weights for the truck, but close on rear axle by 360lbs. Front fender come back to same, but Ford wants a 50% return????, and the weight almost all returns sans 40lbs. Should I back off the jacks? Trailer looks level, still some sag from rear of truck at 1-1/8". Tongue weight % is almost 18%. Would going to a straight stinger as oppose to a 2" drop maybe lighten the load, but then I think the trailer would be slightly nose up? I also still haven't packed all the kids crap in the back bunks.
Took out on I-80 today in PA to get to the scale, seemed to tow fine, was running 65 getting passed by dump trucks and semis, no sway, not a lot of porpoise at all, little squirm from the P rated tires and independent rear. But all in all a good tow.
Any Feedback would be appreciated!!!!
Thanks!
casflynn is offline   Reply With Quote
Old 10-04-2018, 02:07 PM   #2
I have a general, probably dumb, newbie question: how can the trailer weigh less than its dry weight when the WDH isn't hooked up? Is that normal?
2017 Mini Lite 2304KS
wannabeowner is offline   Reply With Quote
Old 10-04-2018, 02:23 PM   #3
Tongue weight, gotta add the tongue weight to the trailer axle weight
Old 10-04-2018, 02:34 PM   #4
MillMitch's Avatar
I think your numbers look good, and would drive it some more before adjusting. Man those Expeditions are big
I put your TT at 4900#, combined of 11,200 less truck by itself of 6,300
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 10-04-2018, 02:36 PM   #5
Chief T's Avatar
To get true numbers, you need your Expy and TT loaded as if you're going on a trip. That includes all the pax and stuff as well.
If you can't get the TT level, slightly nose down is better than slightly nose up.
Also make sure you add air to the tires as close to the max cold psi.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 10-04-2018, 03:17 PM   #6
Chuck_S's Avatar
Very nice job!
Can you post or forward the actual Excel sheet? I hate to reinvent the wheel and we have the same truck. I'm only showing 1418 pounds of cargo capacity vs your 1488. I have the HD Tow Package. You?
I noted you have less weight on the front axle than when empty meaning it's unloaded albeit slightly. You need more weight transfer ("more WDH"), not less, to push the front down. I'd try to push another 100 - 200 pounds or so to the front. This is where it gets very much trial and error as any change will also push weight to the trailer axles. Good luck, though, the Hensley hitch is a complete PITA to adjust and seems needlessly complicated. If you push more weight onto the front axle there will be less on the rear and consequently less sag. It's all a matter of distributing the weight.
Recommendation for safe towing is 10% to 15% of the trailer's weight on the ball.
Recommend everyone take advantage of the work done here and note there is more weight on the trailer axle when hooked up with the WDH than just sitting all alone. This is how it works.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 10-04-2018, 03:37 PM   #7
Thanks chuck, to be more specific, I am slightly concerned that by returning back most of the weight to the front axle, I also returned most of its height change, which goes against what ford says. They state a 50% fender height return in the front.
Yes, HD tow, and whichever engineer said one of these things could tow 9200lbs is just plain nuts, I understand that number is stripped down with minimal tongue weight, but to other camper tow guys out there, I think 6000 ish loaded would be the max
Old 10-04-2018, 03:40 PM   #8
Try this, https://www.dropbox.com/s/och5g6y4ds...late.xlsx?dl=0
Old 10-04-2018, 06:50 PM   #9
Your numbers look great. I would leave it alone.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-04-2018, 07:55 PM   #10
clarkbre's Avatar
casflynn:
Your numbers look great and I don't think I would change a thing. It's awesome to see that my spreadsheet was useful for you.
I recently traded the F150 for a F250 and have to rework the hitch and spreadsheet.
Safe travels.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 10-04-2018, 09:06 PM   #11
I'd try the next step on the bars. Push the front down a little and a little less drop on the rear of the TV. Essentially leveling the TV a little better.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 10-04-2018, 09:29 PM   #12
Originally Posted by clarkbre View Post
casflynn:
Safe travels.
Thanks for it, have found it a few different places, never was sure who came up with it, hats off to you
Old 10-05-2018, 08:26 AM   #13
Chuck_S's Avatar
Perfect is the enemy of good enough. And this setting is well within the later category.
-- Chuck
cat
