Old 04-03-2013, 08:32 AM   #31
20 lbs either way is not going to be noticeable. You are over thinking this. Your setup is about as close to perfect as you can get.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-03-2013, 08:34 AM   #32
Fulltime family RVer
^^^^ sigh, the story of my life.
Old 04-03-2013, 10:00 AM   #33
ependyad,
X-2 ....... Just know you won't have a WHITE KNUCKLE driving experience and
enjoy your family... nice work on the set up
grayfox is offline   Reply With Quote
Old 04-03-2013, 10:10 AM   #34
Thanks. I made a point of going against recommendations by family who camp and got the dually anyway. At this point, I'm glad that I did it - even with the hassles that come along with it.
Old 04-03-2013, 10:54 AM   #35
jevanb's Avatar
My pin is about 2 to 3 inches fdw of my axle, I installed it to the manufacturer directions and my tk has a locating hole to start the hitch install. When I scaled I am setting about 200 lbs from steer max , and 1k from drive max
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-03-2013, 11:10 AM   #36
If you know - how much does your steer axle change when your fifth wheel is hooked up vs. when it's not?
Old 04-03-2013, 12:19 PM   #37
jevanb's Avatar
I have not had time to get back onto the scales empty yet, I drive past them everyday but one reason or another the truck is not configured
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 04-23-2013, 09:13 PM   #38
If you put some airbags on the truck will that push some weight to the front axle of the truck?
Brandon327 is offline   Reply With Quote
Old 04-23-2013, 09:16 PM   #39
No. Only helps with sag.
MGordyan is offline   Reply With Quote
cat, scales, scaling
