Old 03-19-2017, 03:51 PM   #1
Hitch advice
Just picked up new truck today. Looking to buy a cedar creek 36ckts. Truck is a f350 dually long bed. Need advice on what hitch to buy. Never pulled a 5er before
Rhymaunb is offline   Reply With Quote
Old 03-19-2017, 04:11 PM   #2
I love my anderson ultimate with my short bed truck because it replaces heavy expensive slider hitches. It's light weight and easily removes leaving me my bed to haul stuff. With your long bed I'm sure just about any hitch will do. Personal preference on brand for sure.
If you need the bed of your truck often factor weight and ease of removal.
Kimber45 is offline   Reply With Quote
Old 03-19-2017, 05:46 PM   #3
B&W. Love ours. Easy to remove and install, easy assured connection when hooking up.
Sierra360PDEK is offline   Reply With Quote
Old 03-19-2017, 06:20 PM   #4
X2 on the B&W, it has been a great hitch
spock123 is offline   Reply With Quote
Old 03-19-2017, 06:44 PM   #5
3X on B&W
merlinhomeauto is offline   Reply With Quote
Old 03-19-2017, 06:48 PM   #6
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. A good share of the folks around here run the B&W hitch
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-19-2017, 07:08 PM   #7
davel1971's Avatar
I have been very happy with my Curt hitch
David & Lynn
Old 03-20-2017, 04:29 AM   #8
shorthorn's Avatar
Love my B&W... only downfall is it's heavy to lug in and out.
Whatever you choose Pull-rite, Anderson, and B&W make there hitches in the grand old USA.... Curt & Reese are made in China.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 03-20-2017, 05:31 AM   #9
davel1971's Avatar
Curt is USA made.
David & Lynn
Old 03-20-2017, 05:57 AM   #10
Make sure that whatever you buy it has the two hooks that wrap around the pin and not a slide bar that slides in behind the pin. Also get the size one larger than what you think you need, saves buying a larger hitch later.
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 03-20-2017, 06:05 AM   #11
shorthorn's Avatar
Originally Posted by davel1971 View Post
Curt is USA made.
Curt is a US company... makes some in the US... 5er hitches are not.
Old 03-20-2017, 06:43 AM   #12
TURBS's Avatar
I have a curt Q20 and love it!
Old 03-20-2017, 07:40 AM   #13
AquaMan's Avatar
I HAD a Curt Q20 very similar to yours and loved it also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-20-2017, 07:46 AM   #14
BandJCarm's Avatar
B&W Companion with turnover ball.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-20-2017, 12:25 PM   #15
TURBS's Avatar
This one looks exactly like yours!
Old 03-20-2017, 12:57 PM   #16
I see that the 36 ckts has a listed pin weight of 2500 lbs and a gawr of 16,500, so if you are not full timing and are like most of us, you're pin weight will probably be a little over 3000 and a towing weight of 15,000 +/-.
My trailer is a little smaller at 13,500 lbs and a pin weight of about 2600. I tow with an F350 SRW short bed truck. I had a B&W turnover ball gooseneck hitch installed in the truck. Then I replaced the stock pinbox with a Reese Gooseball. It uses the fifth airborne technology that has dual shock absorbers and an airbag in the pinbox. It locks up tight to the truck, and the chucking caused by highway expansion joints has virtually disappeared. This hitch setup is the most user friendly hitch I've ever owned, and there is nothing that I have to pickup to clear my truck bed except for the turnover ball itself which is maybe 10 lbs. I've used this for a couple of years now, and would absolutely buy it again. As a matter of fact, I took the old pinbox and stored it so that if I ever trade trailers again, I can reinstall it and keep the gooseball hitch.
Good luck with whatever you choose.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 03-20-2017, 03:15 PM   #17
For years was happy with my Pullrite...switched to the AU and am even happier...GL
Flagstaff Classic 8321 KBS Ram 3500 Dually
bobsue1 is offline   Reply With Quote
Old 03-21-2017, 06:43 PM   #18
BDavis's Avatar
Curt Q20 from etrailer
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
hitch
