Forest River Forums
Sunline User Photos
Old 02-01-2012, 09:20 AM   #21
frankm's Avatar
I have the Equalizer WDH and use their lube, High Performance Lubricant. Using it has made a considerable difference in announcing our arrival at CGs (little or no metal on metal noises that wake up the dead) and more importantly NO difference in the handling the sway of the TT. I wipe it off after each trip before putting it away. I'm sure the other lubricants/greases mentioned earlier in the thread would do as good a job.
Frank & Rita M
2008 Ford FX2 F-150 3.73 CC 139" WB w/EQ4 WDS
2011 Rockwood 2702SS
frankm is offline   Reply With Quote
Old 02-01-2012, 12:07 PM   #22
trudinator's Avatar
Originally Posted by campdohbrew View Post
This is a kozzie.
Would have preferred a photo of a GB Packers koozie, but this one will do, I guess.
2012 Rockwood 8293RKSS
2006 Dodge Ram 2500 5.9L Cummins Turbodiesel 4x4
2002 Dodge Durango 4.7L 4x4
Days camped 2011:61 (5/21 to 10/22) Days reserved 2012 (so far!!) 56 Days camped 2012: 9
trudinator is offline   Reply With Quote
Old 02-01-2012, 12:08 PM   #23
trudinator's Avatar
Originally Posted by Terier View Post
What is a kozzie?
I use a $3 rubber hitch ball cover.
We can't find one around here to fit. Found one online for a buck, but the shipping was $5. Doesn't make sense.
Old 02-01-2012, 02:12 PM   #24
volunteer moderator
I am SOOOOOOOOOOOOOO cheap!!
When I fertilize my lawn I save a piece of the bag because it's extra thick
plastic. Cut a square about 8 or 9 inches. Hold it centered over the ball
and fold down the sides. Secure with a rubber band.
If you want to get real fancy you can cut off the corners and make
it stop sign shape.
Also potting soil comes in heavy bags.
I used to use a folded up WalMart bag (still do in a pinch)
but the square of heavy plastic bag works better.
It keeps the grease on the ball and off me and keeps dust or road
grit off when I'm running around with the hitch on there but no trailer.
When I'm towing I can fold the plastic and put on the rubber band to
keep it greasy side in and just toss it in my front storage hatch.
Cozy's are for keeping the beer cold!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 02-01-2012, 03:25 PM   #25
Moderator
mtnguy's Avatar
Apparently, I am too.
I cut up old jeans, and put a piece over the ball, overlap it, then secure with a short bungee cord. The legs of the jeans I put over the spring bars and lay them across the trailer tongue.
Oh yeah, I keep using the same jeans parts.....they are just greasy on the inside.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 02-01-2012, 06:49 PM   #26
Once again, this forum has opened my eyes to new ideas. Who would think a simple thing like this could start such a discussion. Being from the submarine force and seeing the benefits of proper and improper lubrication, I will stick to using grease (pun intended). Although I am a mechanic, I'm glad I found this forum and am able to have open discussions with others more versed in the art of RVing than myself.
Me, Her, Boy(8), Girl(7), Baby Girl(1.5) and Dog
06 Chevy 2500 4x4 crewcab SB Duramax/Allison
08 Flagstaff 831BHSS w/ Reese Dual Cam
"Submarines once, submarines twice..."
dc31bhss is offline   Reply With Quote
Old 02-01-2012, 07:14 PM   #27
Has any one tried a grease-less hitch ball.
4runner is offline   Reply With Quote
Old 02-01-2012, 07:19 PM   #28
If they are the same as a grease less ball joint or tie rod end I don't want one.
2011 Salem 30kqbss
2009 Ram
Malco is offline   Reply With Quote
Old 02-01-2012, 09:53 PM   #29
Moderator
Terier's Avatar
RE: Hitch ball cover
CW sells it online for a couple of dollars but you will need to wait for the "free shipping" periods otherwise you'll be in the same boat.
It's almost impossible to get it on without some type of lubrication. I used to remove the hitch when not towing but it's too heavy for me to lift so now I keep it in. Within of a week of leaving it in place the ball started showing signs of rusting so I got the cover.
16 Trips / 43 Nights / 1204 Miles
Old 02-11-2012, 08:55 AM   #30
Mountainmanbob's Avatar
I have seen at least two that wore through
For your coupler, jacks and bunks on boat trailers, it’s also largely a matter of inspection. Check your coupler for proper function. Be sure the coupler latch moves the collar that locks under the hitch ball. Also, look up into the coupler to inspect wear. Though it is rare, hitch balls have actually worn through the top of the coupler, so it’s a good idea to grease inside the coupler so the ball has some lubrication. Shoot some penetrating lubricant, such as Prolong or WD-40, into the moving parts.
How to maintain a trailer
http://www.onlinetowingguide.com
and had to be replaced
but should be noted
these were on trailers used every work day
over many years
Mountainman
Mountainmanbob is offline   Reply With Quote
» Online Users: 587
111 members and 476 guests
1l243, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, autorot8, Bandit114, Barney1, bclemens, biken201, bikendan, bob34787, bobbygee, boubou, brandon0214, Browndog, Cafjackracing, case1175, chiro, chof16, CM BOXERS, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, djorgensen3, DonG, Dukejr, dummin4fun, dunnnc, elind, frfan, gbpacker, Gizzerd, Gman88, Gollum, Happy Vibe, HWII, isz, itat, JamesR, jasni, JJones, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, Kevin-and-Julie, kfroe, kjoh75, LFugate, lochsa, lowbubba, Mad4sax, merlin66043, mesquiteguy, mhartzel, mia, Mr. Legato, mrmurph, mtnguy, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, ret2006, rjshiflet, rkswyo, rodcop9405, Rogue69, ronhanson, Rsgtivr6, rstewart06, SabreMarv, SabreSam, Sailfish Bret, sbond, ses, SimchaSabre, skippy31405, snowbrid, spike, steeleshark2, Steve7575, TheFlagGang5, Tincup13, Titleguy, tking1866, tmmar, toleworks, tomjsas, torben, Trailblazer, viper48, VTX Al, wayne anthony, we2lovecamping, whj77372, Wichitalineman, woodchomper
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
