Old 02-24-2015, 04:11 PM   #11
Mattpopp's Avatar
Most 5th wheels have the front cap designed so that a sliding hitch is a thing of the past. I pulled a Cyclone for a couple years in a Mega Cab without a single issue. You could almost jack knife the rig with out issue.
I would invest in a hitch once you know what trailer you are getting. If it has the short bed cap then just get a ford with the factory 5th wheel prep and a B&W hitch for the Ford. No need in all of those moving parts and wasted moeny if you dont need it.
2014 Cedar Creek 38FL
2012 F350 DRW,
1980 Wife
Mattpopp is offline   Reply With Quote
Old 02-24-2015, 04:41 PM   #12
MtnGuy's Avatar
But what if the trailer doesn't work with the hitch that you choose ?? Then you have wasted your money on the orginal setup, because you now need to get another 1.
Another question for short bed owners: I understand the concept of the curved cap allowing a tighter turning radius. Figuring the axle is 1/2 way centered under a 6.75' bed, then that leaves about 3.3' forward of the axle, plus maybe another 2 or 3 inches to the cab. But when turned at a 90 degree angle, a 100" wide trailer is going extend 4'2" forward. Are the pin boxes extended enough to put the trailer on the outside of the cab ??
Old 02-24-2015, 04:54 PM   #13
Mattpopp's Avatar
Its the recessed corners of the cap giving you the clearance. Not how far the pin box is extended.
That is why I also said, "invest in a hitch once you know what trailer you are getting". Why would anybody buy a hitch before they have yet to figure out what kind of trailer they are getting and pin box setup???
2012 F350 DRW,
1980 Wife
Old 02-24-2015, 04:55 PM   #14
jtstromsburg's Avatar
No completely. But on my old f250 CC SB, and pulling our Sabre with the rounded front, I could get almost 90 with no problems. This is because of the rounded front. It cut back almost 8 inches or more and helped to prevent contact.
Now I have a long bed so should have no problems. One thing I'll comment about hitches, our B&W companion saved our truck from rolling as it is designed to break in half in the event of a rollover. Two pins bent, which allowed it to separate into two pieces. Saw two other pictures of truck and fiver that got pulled over by the fiver and ended on their side or top.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-24-2015, 05:04 PM   #15
I have the 6.8 bed and I can turn a long way, but not 90'. I thought it might be fine, but when you need it you might want the slider. It was an easy decision for me as we already had the GN turn over ball. The DW says get the slider, its only money and it will cost more if you put it in a bind. Makes sense for us since we plan to go to some tight places. Even our driveway is narrow, full of trees, and sloped; so it was a good choice. Oh, and only had the hitch two days when I needed to slide it... But as others say, it is what you are comfortable with.
Enjoy the new rig!
9.5 year old FR Cherokee 295 WP 32' toyhauler
2013 Ford F250 SD CC 4X4 4.30 gears
Tuned-- engine, music, and exhaust,
bpadamson is offline   Reply With Quote
Old 02-24-2015, 05:21 PM   #16
Mattpopp's Avatar
Hitch problems solved. Nothing will hit your cab now.
2012 F350 DRW,
1980 Wife
Old 02-24-2015, 05:38 PM   #17
B and B's Avatar
I have a 5.5 box and Reese Revolution and a Reese 18 k with pucks under bed. I can and have turned 90%. The hitch works well, a little chucking set up on concrete roads (i69 in MI) otherwise smooth.
I just had the sales manager for major RV parts distributer drop off my new generator yesterday, wishes he could sell Reese.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-24-2015, 06:46 PM   #18
I am in same boat and have a 2014 Ram3500 with factory pucks and 6'4" bed. Getting ready to order a TH and been considering B&W drop in for the pucks and a sidewinder, or an Anderson Ultimate fifth wheel hitch, or a Superglide.
I am going with the B&W drop in with the Sidewinder. This is the most expensive option, but the SUperglide would need to be mounted on top of a picture frame adapter that drops into the pucks...there is no vertical adjustment on the Superglide and many people are having issues with the front of the fifth running nose high because the new HD trucks sit up so high (my Ram is completely stock and the bed rails are 59.5 inches tall.
gtsum2 is offline   Reply With Quote
Old 02-24-2015, 07:08 PM   #19
Jbuntingsr's Avatar
Can you use a sidewinder with the drop in hitch?
Jbuntingsr is offline   Reply With Quote
Old 02-24-2015, 07:16 PM   #20
Yes you can. I asked etrailer that question and since the b&w puck hitches are locked into the pucks you can use a sidewinder with them. They do not recommend using a sidewinder with the b&w turnover ball hitch though
hitch
